Torque Settings
simmsy
From a post in 2004 by someone named Viking. This should probably be a sticky too.
Tightening torque Rev3:
Shock absorber-Swingarm 45Nm
Shock absorber-Frame 45Nm
Connecting frame rod-frame 23 Nm
Cylinder-Crankcase 20-23 Nm
Primary drive gear 120 Nm
Handlebar 25 Nm
Engine-frame 50 Nm
Swingarm bolt 90 Nm
Front wheel axle 65 Nm
Rear wheel axle 65 Nm
Steering stern bracket 25 Nm
Rear fender bracket 10-15 Nm
Front brake pad 20-23 Nm
Rear brake pad 20-23 Nm
Engine Head-Cylinder nuts 15-16 Nm
Front axle fixing nuts 10 Nm
Flywheel 140 Nm
1 Nm=0,1 kgm
Handlebar 25 Nm
Engine-frame 50 Nm
Swingarm bolt 90 Nm
Flywheel 140 Nm
1 Nm=0,1 kgm
Is this correct? I was told by Beta that the Flywheel bolt should be tightned to 70 Nm
