Thanks guys, hey houseape, yes it's the same guy. You're right bout the clutch being ok to hold still on but I couldn't paddle back or get neutral with the engine running so was struggling with positioning, suppose i should only be going forwards though... it'll come. I've got the day off today so will be trying some stuff i read on this site regarding mirrors, wet n dry and the clutch plates. I moved the lever adjusters to suit my span so probably f'd up a bit there. will reset and try bleeding again. the fittings are a nipple at the top and a banjo on the calliper . I replaced the banjo bolt with one that has a bleed nipple in it as i couldn't see any other way of getting air/old fluid out the system. To be fair the bike was fine to ride but everything i get comes to bits after a bit so i can go through it all and clean, paint, fix etc as req.
ta redbull, syringe in the shed so def try that in a bit.
