tltel
529 -
when you cleaned carb did you clean out choke enrichment jet, assuming you have one, it can get over looked. You said you checked woodruff but then said you were waiting for a flywheel removal tool ???. the symptoms you describe sound like failed woodruff to me! TLTEL
yes. what he said. much smaller! TLTEL
Might be worth checking reeds, if you are sure carb is clean, Those Keihin carbs seem like a p.i.a. (never had one on a modern bike) Maybe time for a decoke. TLTEL
From memory, I think you have to drop out the swing arm to get to master cylinder. Its only two bolts that hold M/c in place but there is not much room and as the pipe runs inside the s/arm It is a bit awkward. TLTEL
Hopefully you have fixed the problem, after many years playing with and riding these bikes, TL's TLR, Xr and Cg's when ever I refit a carb Always check the throttle snaps back when I tighten up the flange bolts . Carb to insulator. Fit nylock nuts so they don't have to be too tight. The carb body distorts if you over tighten and the slide Jams open when you least expect it. I learnt this many years ago and it was very painful!! TLTEL
I bought one a few years ago from ebay, but not one advertised for a trials bike it was very cheap, I have used it lots of times and not just on gassers. TLTEL
The shoes in my TLR 200 are much smaller than the ones in my TL125 both have the interchangeable front and rear, Im guessing then that the 250 ones are larger than the 200. TLTEL
pschrauber, it sounds like you are suggesting that the rules are irrelevant and the observer gives points on his/her opinion of the riders skill. Its not ice skating, its observed Trials! TLTEL
as said , you need to split the cases and find the problem. if you keep riding it like that it will be scrap. TLTEL
Nice looking bike, welcome back to trials. I also have back problems and find a session on the bike better than any other pain relief I have tried!! TLTEL
Gasgas 300 - Can You Get The Barrel Sleeved Down To A 250Cc?
tltel replied to shercoben12's topic in Gas Gas
also a bit late, what happened to the Jotagas Ben? TLTEL -
Just because its on a trials bike it doesn't guarantee it was designed for a trials bike. Most newer bikes don't seem to be designed for our wet muddy ground. (south east England) TLTEL
check out hook woods In Surrey think if you join up you can ride pretty much any time. TLTEL
We Are A Dedicated Bunch.... Clean... Ride, Clean... Ride!
tltel replied to mags's topic in General Trials Talk
I clean my bike after most rides, but I don't dismantle it to do it. I don't have the time or feel the need when it is only going to get dirty again next ride. I check it over usually night before a ride, before I load it in to the van, oil and adjust the chain if needed then ready to go. I change the gearbox oil every few months depending on how much riding I have done. TLTEL
