tltel
    529
Posts posted by tltel
  1. bambam-n-chunx
    As I said, just reading between the lines,it wasn't a" bite", just observation.
    When my son started riding (I think he was eleven) nothing would have stopped him wanting to ride.
    I hope you can find somewhere that he can get to practice where he is comfortable, not sure how your begginers trials work up your way, but I did one yesterday in Kent, they set out 4 routes and you pretty much ride what you want.
    Some small lads where just riding between the sections, great way to learn the basics.
    TLTEL
  2. View from out side, just going by what I have read on this site, it seems there was a bit of a communication problem, I would have thought that a competition of this size, organisers would at least be able to text riders with information.
    Please note not criticising the organisers / volunteers
    TLTEL
  3. Thanks for the replys guys, have just placed another order with splatshop, getting a new primary gear(think the clutch basket gear will be ok),also the ratchet that Zippy mentioned and some other bits and bobs. Will let you know if these improve the situation.
    Fingers crossed that it does fix it without needing to split the cases again. Hope it hasnt cost too much so far. Its a great feeling when you solve the puzzle and you should have a good bike when its done.
    I sometimes think every one should be made to strip and rebuild a motor just to see what happens when you stomp on that gear lever with a size 10 boot or stab at the kickstart with out taking up the slack in the gear first. It makes me cringe watching some people starting there bikes, a guy told me on Sunday that he had snapped three kickstart shafts and thought it was a design fault, Then I saw him start it. :wall:
    Sorry slightly off topic rant there.
    TLTEL
    • Like 1
  4. Hi
    check that the throttle tube isnt squashed or distorted, or full of mud causing it to bind on the handle bar, if its a domino then there is no spring.
    I did use a slow action tube for a while on my 350 gasgas but went back to the fast. As Chuckindenver says, I also find the smaller wrist movement to be more comfortable.
    TLTEL
  5. Hi Hoodie2
    That doesnt sound right, that surely means that the valves are open. You need to set timing at tdc on compression stroke, so it was probably right before. Not sure where you got your infomation from, the mark on the cam sprocket should be at the top.
    Connect it up and run it through a firing cycle by turning the crankshaft with a socket bar, watch how the valves open in relation to the piston position and when the points start to open at the top of the compression stroke. It will help you to understand how it works.
    I wouldnt worry too much about carb settings till you get it running, these engines will usually run as long as you are getting some fuel in.
    TLTEL
    • Like 1
  6. just had the same problem getting the 6 bolt rear sprocket for my JTR, Loooked at quite a few sites and there didnt appear to be much available.
    Was looking for a 40t rear , ended up buying a 42 tooth listed as a Sherco sprocket.
    have since seen them on Splatshop site and sandifords are selling them on Ebay.
    TLTEL
  7. I will always be a Rossi fan, and really enjoyed watching Sundays race, I was on the edge of my seat for the last 5 laps, I cant remember the last MOTOGP Race like that.
    Regardless. if you like Rossi or not this season looks set to be a good one, I think Marquez was brilliant and see him winning the next race as they say its a Honda track and none of them have raced there yet.
    I can't wait.
    TLTEL
  8. Hi Clav3
    just thinking on what you have said,I suppose its possible that in my case as the squish was very tight ( it almost cut through the solder I used) and there could be a small amount of movement on con rod, when the engine is hot and things have loosened up and expanded, the squish clearance would be vertually nothing and could cause the knock.It is a 95 engine so there must some wear. It sounds really good at the moment.
    Let us know how yours turns out.
    TLTEL
  9. Sorry, but I find it a bit hard to believe you would do all that work on an engine and not check the con rod for wear. I think probably any engine I have taken the top off I have had a look to see if there is any movement, also that you didnt check the squish clearance just out of curiosity before removing the head again. I don,t think you said what engine it was, but am assuming its 290 sherco, and I think probably the squish is more important on the larger capacity engines,
    Just my thoughts!!
    TLTEL
  10. Welcome to the Forum.
    I had an SL for a few years back in the 80's, I had to keep welding patches on the exhaust were it rusted out, in the end there was more patch than original metal.
    I wish now that I had taken photos of all the bikes that have past through my hands.
    TLTEL
  11. sorry I cant help with the magnet positions at the moment, but it does look the same as the TL set up I think I have got a spare I will try to have a look.
    The advance unit does look different to mine (from memory, not seen it for a while) yours does look very dry, a bit of lubrication might help things move a little easier.
    No supressor in plug lead on mine.
    TLTEL
  12. Hi
    If you look on the forums,there are instructions on how to check squish with soft solder, its eay to do. I had issues with my gas gas when I bought it and the knock does sound quite serious, although there were no signs of the piston hitting the head there was almost no clearance, i fitted two base gaskets and took the clearance up to 1.5 mm, that was about three years ago, and its still fine.
    hope this helps.
    just remembered, rather than buy the gg gaskets I bought several sheets of different thickness gasket paper and made my own, much cheaper and easier to get the right thickness.
    TLTEL
    Yes . What Dom Said. He posted while I was writing.
  13. Hi
    Just a thought on your advance / retard unit, i had one from an xl engine and tried to use it, just because it looked newer than the TL one I was using, on close inspection the slot that lines up with the dowel on camshaft was in a different position and the springs and weights were different too.
    So it may be that you need the camshaft and advance unit from a CT to make it all work properly with the CT stator..
    Interesting about the stator / magnet positions being crucial, I supose it is not normaly some thing that crops up as its not usually variable.
    Presumably the reason it worked ok with the battery set up is because you had a constant power at the coil/points.
    Hope you get it sorted.
    TLTEL
    Just wanted to add, If the advance / retard is wrong it might rev if you raise revs slowly, but not under load or quick opening of throttle
