tltel
    529
Posts posted by tltel
  1. hi
    I had this problem once, ruined a new seal and had to buy the complete kit again.
    I always lube every thing with the brake fluid and make sure the seal groove is clean, its usually the outside of the groove that you cant see that has the muck in.
    I made a small L shaped scraper to get in the groove.
    Make sure there are no burrs on the piston (puck) and push in with your fingers and twist a little as it goes in. ( thats the piston that you twist!)
    Good luck.
    TLTEL
  2. HI
    I have a 95gg320 and my son has a 94gg125 which both have the two two piston AJP calipers.
    Both front brakes are very good and will only ever need one finger to stop even on steep long hills and you can easily lock up the wheel if you want. My son is 15 and loves to stand his bike on the front wheel (stoppy).
    There is very little actual movement in the lever and they both feel solid. I have the short lever and my son has the long levers on his bike.
    Sounds like you still have air in your system, or as jon said your master cylinder is worn out.
    I changed a weeping caliper seal on saturday, refitted caliper bled system and all working fine, took about an hour for the whole job and was working great. (it still worked even with the calliper weeping.
    Basically the brakes are plenty good enough.
    Also worth mentioning, I only buy cheap pads off Ebay usually about
  3. My best advice is don,t practice in trainers, always put your boots on even for a quick play. My dad taught me that when he put a foot peg inside his ankle practicing in the back garden 30 years ago.
    I still won,t even start my bikes unless I have boots on!
    Practice land is very hard to come by, but a lot of clubs are doing begginer and wobbler days which are good to get started, and fun.
    Good luck
    TLTEL
  4. Oh dear ,i hope you didnt pay too much for this bike.
    first off you should be able to identify bike by engine and frame nos.
    Phone Gas Gas Uk and they will be able to supply all the parts you need and tell you what bike you have.(JTX on the tank is a bit of a clue)
    Sounds like you are over heating and possibly seizing up which is why it stops after warming up,( it could be fuel blockage) I would check that pump is working first,Take the cap off when it is cold and start it, you should see the water pumping around.
    Check the fan by bypassing the thermostat and starting the bike.
    Hopefully the fan will spin and you can replace the thermostat,(About
  5. Hi Sorry but I dont know what jets are in them, they were both bought as complete carbs, sold for 125 hondas and were fitted straight onb even the TLR one. I bought them direct from an Asian website through Ebay (cant remember the exact name) and the delivery was very fast.
    I think I searched for an SL / CB / CL carb instaed of TL as you get more hits and are less likely to be charged more just becacause its for a TL.
    I have also used the same supplier to buy a cam chain adjuster and a couple of carb to air filter rubbers, and they were genuine parts.
    Hope that helps.
    TLTEL
  6. Hi
    Just thought I would add, If anyone is thinking of going to one of these practice days, I can recomend it as a very enjoyable days riding with a friendly atmosphere. My son and I both relatively new to trials found the red novice route spot on, we were able to do six rounds of 10 sections on Jan 2nd and both had the best day trialing ever. Its a good way to gain confidence without scaring yourself.
    TLTEL
  7. timming!! didnt go that far just pulled the lump out
    Just a thought, I have the same bike and my son has the JT125, we had a similar problem and it turned out to be the wires to the coil. We had a spark with the tank and cover removed but when the tank was fitted and we tried to start it it woud'nt go.Only found the problem when it did actually start and then stoped as soon as I sat on the bike. I had to replace some of the wires and reroute them so the tank did'nt touch them.
    I would be supprised if your carb settings would stop it from starting, just maybe make it run badly.
    hope this helps.
    TLTEL
  8. Hi I agree with bobtlr,the brakes on mine are very good,much better than on my TL125.
    It could be that you need new cables this can make a huge difference if your old ones are stretched.
    Also in my opinion there are some very cheap and probably nasty replacement shoes on the market, I would make sure you go for a known brand at least on the front where it really matters.
    TLTEL
  9. Hi
    Just to add to what has already been said, I find mine works beter if you dont kick it too hard, as in let the decompressor do the work and just push rather than kick the starter down, then let it idle a bit before opening the throtle.
    Also if you do kick it over a lot check that you havent bent the kickstart stop bracket under the brake pedal.
    TLTEL
  10. hi
    I had a siezed brake piston in my sons 94 gas gas (AJP same as yours)and tried several ways to remove it but found that the recess in the piston was tapered and nothing would grip it. compressed air wouldnt move it.
    The previous owner had ridden it for a long time without a front brake and it was solid.
    simple but drastic solution was to drill a 5.5mm hole in centre of the piston, tap a 6mm thread into piston, screw in bolt and it will push against back of caliper and out comes the piston, it actualy only took minutes to do and you get new pistons with the seal kit.
    Obviously you must make sure you only drill through the piston and not into the caliper body.
    TLTEL
  11. Hi mark
    I would do as the others have said, but also check your earth connections to coil and condenser, that sounds more like the problem to me.
    I have never known a TL flywheel or generator to fail.
    good luck
    TLTEL
  12. Hi
    Before doing all that work, take the clutch cover off the 150 engine and check the spring arm and roller are engaging on the end of the selecter shaft. ther is a star on the end of the shaft, you can see it move when you select a gear,the small roller engages in the star and holds it in gear.
    sometimes the arm comes loose and stops it working. if my memory is correct you can see it with the clucth drum in place but you cant get to the 10mm bolt without removing the drum. still easier than stripping two engines and you will still have a spare.
    Hope that helps.
    TLTEL
  13. Hi
    I have had similar problems bleeding brakes as I am more used to nice easy cables, but having aquired a couple of gassers in the last couple of years and replaced all seals and pistons I now am reasonably confident about bleeding the systems.
    This has been covered on here many times over, but it seems the only easy way to do it is to push the fluid in through the bleed nipple and up to the master cylinder.
    Start with the reservoir and pipe empty get a large syringe from a bike shop or farm store, load it with fluid and with a pipe fitted to the bleed nipple push the fluid up to the reservoir. you need to make sure there is free play on the lever pin or it will block the tiny hole in the master cylinder and wont let the fluid flow.
    When it is full close the bleed nipple and work the brake lever it should have some pressure but sometimes just tapping the brakeline with spanner will make some air rise up and out into the reservoir.
    I find that you dont get full pressure till the cap is screwed back on and you have used it a bit,
    Also just letting a bit of fluid out of the bleed nipple after using it may expell a bit more air./
    last bit, I have found that it can get a bit messy so do most of this with the wheel and pads removed.
    Hope this helps. TLTEL
  14. Hi
    Not sure what bike you have, but most brake parts for trials are made by AJP or Brembo. You might be lucky enough to find one that matches yours from another bike, I think most are mounted by the same two small bolts.
    I fitted a new one to a 1994 gg Which was for a later model but had to alter push rod length to make it work properly.
    You will more than likely have to buy new as they are prone to wear from dirt getting inside and scoring the bore so a used one is probably false economy. (new one was about
