wingandaprayer
42 -
Hi, try cutting your frame guards at the curve, that way you can check bolts with guards on. cheers
No,, not a atv type lanyard, just a normal cr/yz/rm/kx type would be ok.
Hi, fit a moto cross type kill switch and problem solved ! cheers
SXS fit really nice and well made to cheers
it looks like John Mcguiness, Guy Martin and my old mate Bruce Anstey were the top 3 today. cheers
three letters to say to you mate, BVM, helpfull and very efficient.
sorry to dissapoint chewy, but there are more of us than you think, check out dr jj and beaver ( awesome bands !) from a would be drummer !
Hi, I'm pretty sure the ridge points up towards bars.
I can see they have taken there time in thinking of a new colour scheme ( very beta like ! )
Hi, you can put a slow action throttle on it ( black tube available from most trials dealers ) and also a thicker base gasket and a head spacer, should calm it down quite a bit. Hope this helps. cheers
Hi, the 42 jet is a alternative to the 36 pilot jet fitted in your bike. If your not sure how to set carb up maybe take them back to dealer and ask him to sort them for you.Hope this helps cheers
HI, Check wheel bearings have no play in them, linkage bearings are ok by lifting rear of bike and feeling how much movement there is before rear wheel lifts from floor, there will always be a slight amount of play that you can feel but it shouldnt be much more than a few mm. check brakes work and there arnt any leaks or cracks in frame. Start bike and listen for rattles when clutch pulled in and make sure its the year the seller says it is. Good luck and if its all good you should pay between
You should be ashamed of yourself ! ( take her with you to the trial, its a day out !) lol
Hi, try 1 1/2 - 1 3/4 turns out on mixture screw. cheers
Can someone put a sock in his mouth
wingandaprayer replied to neale's topic in World Championship Chat
As good as bou is, it was a 5 tonight, he rolled back with his foot down, Dibs did the same and they fived him. I know he would have still won, but at least it would look a lot closer on the results sheet. You got to have consistent marking regardless of level. cheers p.s. I know jb comes out with some drivell at times but on the whole he aint to bad
