- Finally!!
- Finally!!
mr bill brown
Not sure if you have sorted this out yet. It looks like a 1981/82 model to me. To be sure you could drop a line to In Motion Trials in the UK 01784 440033 and let them have the engine/frame number.
TXT 250 year 2000.
Hi, did you have any luck in sourcing these seals? I have the same problem on my 2001 txt 250 with Hebo calipers F&R. The calipers are not too bad, but I could do with some pistons and seals. All the best
Exhaust ID
After a bit more research (picking brains) it seems most likely to be for a 248 Cota. Surplus to requirements, so if you need one please drop me a line.
Exhaust ID
Hi, I have a NOS exhaust pipe for a Montesa. I bought it for my rebuild (1979 Cota 349), however, when I came to fit it, it wasn't right. The part number on the expansion is: 2180 03803 or 08808 (photos attached). Any help would be appreciated, thanks.
Bultaco ,, your picture all models
Model 124 brought from a private collection. Never trialed!! The same model, colour etc that I learned to ride on when I was 10 years old.
TXT249 2001 seat
Hi Tr1al, Thanks for the info. I think the bonded alloy is going to be the neatest fix I'm going to get. Scoured the breakers/second hand market and couldn't find anything that didn't look as good as mine (apart from it being broken).
Sherpa road register?
Hi Halfway, Not sure how far you've got with this. I brought a lovely original model 124 out of a private collection in Northern Ireland back to the UK. The bike hadn't been taxed since 1977 or registered in the UK mainland. DVLA were great, and sent an engineer to inspect the bike FOC. Only took a few weeks from sending the info in to DVLA with the correct form completed (V5 request) as well as possible. I now have a V5C in my name and showing me as the first owner. Result!! If the bike has never been registered and you want an age related plate, I think you have to first get a dating certificate from The Vintage Motor Cycle Club Ltd. I only have to decide now whether to get everything polished and sort the chrome out before I compete on it, or ride it as is.
TXT249 2001 seat
Hi, I'm not sure if anyone can help with this, but any suggestions would be well received. I am looking for a new/good used seat for my 2001 TXT. After trawling through forums and calling dealers, I'm told they are no longer available (in any colour) and I am struggling to resolve the problem. Any ideas for a strong repair would be welcome, unless you know where there is one, preferably in the UK. I've done the zip tie trick to stop the mudguard flapping about, but it's not ideal. If anyone has used an alloy plate to bridge the two parts, how did it hold up? Thanks in advance ๐ค
Bultaco Sherpa, brake light needed or not.
Thanks guys for the replies. No lights fitted from new, which I know could be had, probably as an option. The reason I bought the bike was because it was the exact model, colour etc that I learned to ride on (in 1st gear) when I was 10Y/O. I have a photo of my dad's bike which he used to commute to work on, and he only had the bulb horn, front number plate (as this was required I believe at the time) and his rear number plate, both black backgrounds and white numbers/letters. No lights at all.
Recently purchased from the original owner, a 1975 Bultaco Sherpa 250. The bike was registered in Northern Ireland and I have brought it back to England. I have sorted out the registration as it only had the original hand written document issued in NI. So, a new V5C has been issued after DVLA sent an engineer to check it all out. The bike is exempt from road tax and MOT, and as no lights were fitted when new, it does not have a brake light. I realise I can only use this bike (on the street) during daylight/good visibility, but would anyone know if I have to fit a brake light. I have read elsewhere that if the brake light wasn't fitted from new then it is not needed. But this was a classic bike forum and not specific to trials/off-roaders. I know for safety it would be good to fit one, but this detracts from the originality. Any advice would be greatly appreciated. Thanks
Mk1 Cota 349 Piston Ring gap
Thanks for the info. ๐
Thanks for the quick reply Majesty! I have a list of parts for the company you mentioned, so I'll give them a try. Thanks again
andrewb changed their profile photo
Hi, It's been a while since I last posted. I am finally getting round to rebuilding my Cota 349 1979/80 (an early one). It's only been stripped and in boxes and drawers for the last 12 years, so I'm moving quickly on this one๐คช. Can anyone let me know the correct piston ring gap for the standard bore please? The bore is good, not oval, and has hardly any wear, so I am just putting new rings in. I have the new rings but wanted to check the gap before assembling. If I remember I'll post some photos along the way. I've already rebuilt and re-spoked the wheels, frame powder coated, new shocks and forks rebuilt and fitted. Going to have to do the forks again though as I've realised the previous owner missed a couple of parts out. So I'll be ordering new internals. Here's a quick peek at the story so far (if you're interested). Thanks!
