snapper
23 -
Try www.kellycarbon.
Before starting the bike be certain that the throttle closes onto the stop in the carb. Listen to it clicking when you let go of the throttle. Try this while you go from lock to lock with the handle bars.
Hi Mike, If the headlight flasher works I would think that the power for the dip/main beam will be sourced from that possibly from the left switch gear internally. Check with meter or bulb. Happy New Year. JK
Try Richard Thorpe (PJ1 Man), close to you and has contacts at Craigs. r.thorpe146@btinternet.com
You could try Kelley Carbon Tel.01470 562777. Google Kelley Carbon to view products.
Falling off hurts more and takes longer to repair!
Not really, something about an inch wide X eight long, eighth thick should do.
Pop Rivet a Strip of Alloy for and aft of the brace to the underside of the fender.
I have a full size plate that I attach to my back pack and a small size on the bike.
Give it to Peter Gaunt, he would make it work.
The SCOTT might be a starting point. It would at least give the camera crews a work out.
An old car aerial on the helmet, and a couple of earthing srips to each boot should do the trick. I WILL GET YOUR PHOTO!!
Shocked. Have known John a lot of years. An old Eastern Centre friend. all my condolances. Jack
