gasgas
    220
  • Website URL
  • ICQ
3,683 profile views
  1. Hi guys, been a while since i was on the forum, but not that i quit riding, on the contrary. Last weekend i had a small crash with the bike. I went over the bars downhill. ouch. Picking the bike up i noticed my clutch was gone. So it sucked some air in at the lever. No big deal. But i was wondering, since i still use the brake fluid, can i swap for mineral oil, without much hassle? Can i just ask for a 2005 ajp piston that is suited for oil? I believe i already have the green o rings at the clutchside.
  2. gasgas
    TR 280
    I rode it last weekend, and the suspension is good. Throttle responce is lacking though. It wld not responce/rev like mine 250cc pro. Mapping issue, so probably changeable. Bikes feels lite and balanced. Hopping no problem, front and rear. I had to return the bike to the owner, so no more chance to play around bigger obstacles. Did not want to wreck it
  3. Hi Trialers, do we have a cheap fix for this fan? It is outof a Pro250 year 2002. It looks like this electromotor is complete package, right?
  4. Yes, you can hit a crank out of true. I have done that before I also install the bearings first, and they have a tight fit in the house. Thanks for yr replies.
  5. central in the crankcase mouth where the barrel fits, you are right. Normally you try to achieve a crank that has the same play between the cases both left and right. That wld be the perfect fit. But now my crank is a little bit to one side. More play at the primarygear side , so to say, but still crank won't touch the case, lucky enough. Anyway, seemed that it was like that before splitting the cases so i let it be. Time will tell if it causes a pinch crank/case situation.
  6. Hi guys, it was maintenance time, so replaced a few bearings inside the cases. Did everything as per instructions. Shrink the crank in the freezer, heating the rightside bearing to get it wider, dropping in the crank untill she bottomed. Putting the leftside case on, has a slip-on fit on all bearings, so no sweat there. Closing her up, with the bolts, nice and tidie. Everything turns and goes, great. Only thing is, the crank is not evenly centered between the cases. The rightside, where the primarygear sits, has more clearence between the cranksheek and case as the other side. Can not center is by hiting the left, so it is as it is. I can live with it, as the piston and big-end has enough side clearence anyway, but have others noticed this too? Stupid thing is, i have done this job one other time before, but did not noticed it then. So any one who is experienced with the job, pls reply. Thanks in advance.
  7. Peter, a little late, but Thanks for the answers. Rgds George
  8. Hi, i have a pro 2002, the mother all pro's, and the dealer is having a hard time to find me the original piston. The original piston comes with a "dyke"-ring and normall ring. I asked him to give me a normall piston but there seems a bit of a confusion abouth that the the cilinders differ from 2002 untill 2008, or so. Is he correct? And also are there pistons nowadays who has intake windows in the skirt? Thanks
  9. Peter, Thanks for the info. With my 2002 crank, i can remove the sleeves for the cranktaps? I always thought they were one solid piece with the crank ?! I already discovered that i need the 6205 ETN9 bearing since these have a smaller innerring and fits the sleeves of the crank. Great help Thanks George
  10. Sorry Mikee, i mend the code like 6205 c4 ...... or c3.... and more if there is. They gave me a 6205c4 bearing from skf explorer. A nine balls variant. The former bearing was a 6205 c4 without explorer on the side and was a 8 balls. The first one, from the dealer, did not fit over the cranktap because of the bigger inner rim. So there are different versions of the 6205 c4/c3 bearings ?! edit: i changed the 6305 into 6205. I see that in the manual of 2003 the nbr listed for the mainbearings is\M01216002/2, 6205 ETN9 2x Can we assume that the bearings changed tru the years?
  11. Hi, wld anyone know the code of the pro mainbearings? And wld they differ within years or did they stay the same all years? Thanks in advance, George ps: reason i ask, i recvd a different mainbearing from dealer as was in it. So are there probably more codes that fit?
  12. gasgas
    Carb Mixture Screw
    Rend, sorry to tell you but there is no exact amount of turns for the mixture screw. You have to listen to yr bike to determine how many turns you need. Out is richer, in is leaner. Your bike/carb may need 3 turns, mine 2,5 etc.
  13. As Jon said, check the carb settings right away. Never assume that something is by the book and check everything that you feel you savely can do. Offcourse not everybody is "bike maintenance capable", but try to become one. It will save yr day, one day.
  14. gasgas
    It Exists!
    Wow, looking at these pics on the france site, it is unbelievable how low and small this engine looks. Like a twostroke. Where are the better photo's? I want to know, again, whether they used a centrifugal flywheel! ps:very slow response compared to that montesa hype years ago.
  15. gasgas
    It Exists!
    http://www.trialscentral.com/forums/index....showtopic=14717 Wauw first spy picture, pitty it is such a bad picture, of the GG Pro 4 stroke. Can we send somebody to the hills with a telelens for better pictures;)? I want to know whether they went for the centrifugal flywheel or just stayed with a conventional one. Anywhere better pictures?
