bruces670
55 -
Thanks for your advice people,I’ve ordered some putoline light,is it ok to get 2 changes out of 1 litre?
Could you tell me the oil spec please?
Hi,what spec is the gp10? Is it sae 75w?
I’ve tried atf I found it horrible,is 300v a brand name?
What are people’s thoughts on best oil? For the best gear change and clutch operation? TIA
Can anybody tell me where the slits are on the breathers pipes on the carb
Altered the float height a little and it hasn't done it again yet but need a longer play on it to be sure,it was doing it when the motor wasn't running that's the bit I couldn't understand.
Does anyone also with an evo know which pipes should have a slit in them? And whereabouts? Thanks
Yes I've got a bit fed up of it so I'm gunna let the local dealer have a look at it!!!
I've put the floats in a bowl of water and they seem fine,I will do the pipe trick and try that,it seemed to be worse this time when I put it back together,which needle and seat are you referring to? The float needle seat is in a recess and I can't see how it would be replaced?
Think I'm gunna gave to bite the bullet and get a new carb,I've done everything suggested and its just pouring out of the pipes,does anybody have a rough price of a carb?
Does the mixture screw work on the fuel or air side?
That's spot on mate exactly what I needed,had been searching the net for a decent exploded diagram,thanks very muchly
That sounds like it sticks out but can't see any holes in it
