nickolino
    8
  1. Now there a new meaning for the sharpest tool in the shed! LoL
  2. Steve you nailed it. I have been in the M/C bussines all my life and am new to trials. I had 1 dealing with Ron Commo and it was perfect good service very helpful and will do business with him again. Smart people know the value of a good dealer the rest they just complain. You can't fix stupid.
  3. Thankyou to all that helped. Just to update since its been a while. Sent the stator to steve at motoplat got it back hooked it up ran it tell it got hot the fan switched on then the motor shut off. Back to the drawing board. Thankyou
  4. Hi, Thanks for all the help. Can anyone tell me what the Ac voltage should be coming off the stator. Thanks
  5. Hi, Thanks for the info. If what you say is true that the fan and Ignition are wired through the source coil then it makes sense. However Beta USA says there seperate. This bike is stock as far as I can tell. The wiring diagram matches what Beta USA gave me. Thanks.
  6. Hi, Thanks the wiring looks original how ever if it was rewired through the lighting coil why would it shut the engine off? I live in the USA so any clues to having the stator checked. Thanks
  7. Hi, Thanks all connections are clean and right as far as i know since its the first beta I have owned. Why would it run perfectly and only kill it self when the fan switches on. Thanks
  8. Hello, Since being a newbie to this I will try my best to use proper english. I just aquired my 1st Trials Bike a 97 250 Techno after reassembly and first run what I have is every thing is fine until the fan switches on then the engine shuts off as if you are hitting the kill switch. What should I do? Thanks
