manxmann3
    27
1,804 profile views
  1. Fox enduro mtb pads are much slimmer than the above ones, I use them. I have both. The bulkier ones will not fit under trials Lycra
  2. Lineaway that is hard to visualise Videos needed!
  3. Dan, when you say rear preload, you mean rear sag? I did set it up to about 30% when I got the bike. I've got Michelin tyres Legs straight or bent for slippery climbs?? Thanks
  4. Hi aircooled4ever It's got a black spring fitted
  5. Anyone see the rear shocks fitted to quite a few bikes at Tong, men's and ladies Looked like remote reservoirs on them, like rally car shocks. Reservoir mounted beside engine Anyone know much about them? Thanks
  6. Yes riders moving up from 80s to 125s should be on lighter sprung bikes Who would know? Lampkins? Thanks
  7. Hi Are there any lighter than standard shock springs? Only got 3psi in rear tyre and can hardly get rear wheel to grip on wet rocks or grass I don't think it's down to too bad technique, my 15stone mate on a beta evo was getting grip everywhere last night I weigh about 65kg Thanks
  8. Hi Got a 2005 Rev 3 250 needs new rear master cylinder The aprilia rs125s of that era had grimeca master cylinders that look identical with 40mm bolt centres Any reason why it shouldn't work if I fitted one There are brand new pattern ones on eBay for 35quid including reservoir and hose compared to 90 for a grimeca Thanks
  9. I've scrubbed up the disk and pads, new fluid in too. Put some heat into the pads and cooled with water Still hardly powerful I think a Honda nissin master cylinder might be the way to go?
  10. Fox enduro mountainbikes pads are good
  11. My girls and a few others in our club wear evoc padded vests. Great protection. Got them from freestyle extreme
  12. Hi Compared to my 2012 beta evo the mont front brake is poor I don't mind spending a few quid of better brake. I'm not too worried on sticking to original montesa specs Can brand new modern gasgas,sherco or others brakes fit straight on? Thanks
  13. Yep tried that one too thanks. Nothing doing. Must be a fueling problem?
  14. Yeah really strange smell. Could it have blocked something with having 2t oil in it?
