boomer
    3
  1. I ended up cutting the nut off and used a punch to get it out. That thing sure was stuck. Thanks!
  2. Thanks for the reply! I've removed the swingarm already. My problem is removing the nut from the bolt, not getting the bolt out - at least not yet. It won't budge even when use a pneumatic impact driver. Just thought I would see if anyone has had this problem before. Thanks!
  3. Hello, I'm trying to remove the rocker arm from my swingam to replace the linkage bearings, but am unable to remove the bolt and nut that attach them to the swingarm. Has anyone seen this issue before? If so, how did you remove the seized nut and bolt? Thanks!
