johnnydudeuk
    26
1 Follower
3,007 profile views
  1. Hi, I have 2004 and initially I was using light gear oil, as I do in my MX bike, but the cold sticking clutch was really bad so I changed to using a standard cheap 10W40 (Carlube 10W40) motor oil after reading in a forum and checking with a few of mates. I've been using this for a while now and it seems to have eased the cold sticking and the changes seem much smoother. Cheap and worth a try.....
  2. Just a thought, could you not find a bolt of the right size to bung up the pipe to stop it leaking? I did this on a unused vacuum hose on my supermoto once and it worked a treat.
  3. The bumps go down, dip, as well as up, bump, and to keep the tyre on the ground the forks need to extend as well as compress and without sag there is nowhere to go.
  4. T and t is closer but their web site says nothing about a service department. I will give them a call in the new year. Thanks.
  5. Hi All, As the subject says I'll be needing a dealer at some time shortly for a rebuild of my Sherco ST290 (2004). As I'm based in Birmingham area, West Midlands, UK, I was wondering if there was a local dealer I could rely upon for this. I was thinking BVM but they are 90 mins away.... Yesterday, I had an issue where my bike just stopped on a cold weather ride and today it started third kick but the plug was black. I was sure it was not clearing out all day and that seems to be right on the money after looking at the plug. I'm thinking that it might need at least a set of rings as the bikes history is unknown. If it was an MX bike I know who to take this to but not sure they are into trials rebuilds. Basically I'd like to get the engine to a known position and work from there. Thanks!
  6. I ordered the same as my shoe size (UK8)and they are ace with seal skin socks. I can even drive in them.
  7. Nice to see a DRZ in action.... I never thought of using mine for long distance trials though...hmmmm ideas!
  8. Hi, Pretty normal for a trials bike. I thought the same when I got mine but a search on here for clutch issues lead to many other with the same thing. Mine is better when I use straight 10W40 car oil in the gbox, not recommended but works for me! John
  9. johnnydudeuk
    06 Crack...
    Hi all, Just thinking about this pivot bolt length issue and relating it back to my MX bike. As far as I can see the threaded portion on my MX bike extends into the hole on the side of the frame and so allows the tightening of the pivot bolt to pull the two side together to take up any clearance on the swing-arm and spacers. This is what the original bolt was doing as It looked to have enough engagement to me. What popped into my mind was, if the swing-arm inner races and spacers were not long enough, then the frame would need to be pulled together too much and this in itself would put undue stress on the side frame rails and this might be worse than a short bolt. Just my musings.... John
  10. OK All, Stand down! I've stopped looking for the diadora spares and looked to more normal machine screws and found some lovely stainless M4 x 6 Pan Pozi Machine Screws on ebay. Next, is to fit them with Loctite me thinks.
  11. Hi All, Just cleaned my Diadora Mud boots and noticed that I have lost 3 of the black screws that hold the front edge of the buckle to the boot. Anyone know here I can get spares from the these boots? I'd guess that they are the same as the stone 3's buckets too. Tried ebay and google so far. Thanks.
  12. That's a good idea! Thanks! By the way, has anyone looked at the notoil replacement filter for the Sherco? I picked one up as a second filter for my 290 and it seems well made but much heavier in construction than the Black/Orange (STD?) one that the machine came with. I might be getting a couple more.
  13. Nope, I just put the clean filters in a plastic bag in the Garage and retrieve and oil as required. <Latex Gloves at the ready> The only bad point with pre-oiling, that I see, is the possibility of them picking up dirt while hanging around my garage as it's not exactly an aerospace workshop...
  14. I'll second the "NoToil" method as I've been using it for years on the Enduro and MX bikes. For my YZ I have a bag of 6 filters and once they are all dirty I stick them into the washing machine with the powder release agent and a bit of normal washing powder and 30 mins later 6 nice mega clean filters..... Easy!
  15. Hi Kev, I have just purchased a pair of these (Trick) as I went looking for something a little less revealing!!! They are still a mixture of lycra but have a fair proportion of what looks like panels that are from a material I have only seen on MX type trousers. Much better and a great fit around the waist area when compared to the MX bottoms that I have been using. This should stop me having to constantly pull them up..... All the best,
