deminimis
22 -
TT, I just ordered the only fork spring in stock from The Splat Shop. Dims are: 365mm long by 32mm outer diameter. Spring rate 0.9kg/mm (8.8N/mm). Cannonracecraft can build you one, but it will cost more than the approx $80 shipped (to the US) Splat Shop price (Cannonracecraft quoted me $175 for two (didn't understand I only needed one)). I am working on dims for the shock and will likely have Cannon build that. If anyone has the factory dims on the shock spring (2008), please chime in. I assume it's a progressive spring as the shock valving is progressive. I'm guessing the rear shock needs to be in the 80N/mm range, but any info would be greatly appreciated.
I generally run 60:1 in my Rev3 and it seems happy. When is very dusty/fine sand conditions, I think it's a good idea to bump up the oil a bit. Ran 40-50:1 last week in Moab (very fine blowing sand) with no ill effects.
Setting Up A Trials Bike For A Tall/Heavy Rider
deminimis replied to brianjonesphoto's topic in General Trials Talk
Thanks Brian. -
Ditto! '08 Rev3 270 and 220 pounds, but looking for the same info. Thanks.
Did you source your springs yet?? -
Also make sure your master link clip isn't making contact anywhere. Makes a nice tick sound. Yup, I did that once.
Thanks. Nope, didn't measure volume. I haven't read about leaving the spring in either, it's just the image in the service manual showed the measurement of 120mm, but the image also showed the spring in place, which was a little concerning. Perhaps the spring in the image was to indicate it was the compression side. Who knows. That manual -Geeszch. Anyway, thanks for the reply and I'm not going to fret about it as looks like I measured correctly. Thanks again. Well I take that back, actually, here's the language from the manual: Left shaft To replace the oil, proceed as follows: 1) Remove the front wheel 2) Remove the handlebar (see pag. 65) 3) Unloose the shaft lock the screws A 4) Unscrew slider plug 5) Remove the spring and totally empty the oil 6) Reset the spring and fill with oil (OJ01 ) up to the level indicated in figure Humm, well, I'm not going to worry about it. Seems to work correctly.
This has been covered, but there is some conflicting info around regarding the oil height on the compression side of things. My service manual has an image clearly showing the spring in the fork tube when measuring the air gap at 120mm ( I chose to use the air gap method instead of measuring volume). However, I've read more than once that to get the accurate measurement, it needs to be done without the spring in fork tube. Did mine last night without the spring, and it feels about right (in the shop, haven't ridden it yet). So, I guess I'm just looking to clarify that the 120mm measurement is, in fact, done without the spring in place, right? 2008 Rev3 270. Thanks!
They are trash. Pretty big gap on them, so they are not doing anything. Will probably try some Seal Savers. Thanks.
I've ordered up some 38x50x8 fork seals, but they do not come with dust wipers. Dust wipers by Paioli (at least in the states) are extremely expensive (and, frankly, pretty crappy as compared to other wipers, at least the ones i have). So, wondering if anyone has figured out a good cross reference for the dust wipers that fit from other, non-trail bikes (i.e. Honda, etc.)? Thanks!
Got it! Banjo washers were not up to snuff. I have a clutch again.
Oh crap. Perhaps I did this wrong. Hopefully someone here has installed a Grimaca clutch master cylinder seal kit and can help. When I installed the new kit, I did it the same way I found it. Was looking at a PDF file just now that seems to suggest the way I did it is wrong. Specifically, I'm talking about the small cup like seal towards the end of the piston (not the "O" ring): Does the open (cup part) go on so its facing the hose (to the right) or to the left? Hope that makes sense. I have it so the cup (or perhaps better called the larger flared end) is facing the hose end instead of facing to the left (clutch lever plunger end). That makes the most sense (would apply pressure when needed and allow fluid to blow by from the res (when needed) when the clutch lever is released. Again, the pdf image seems to suggest otherwise, so any words of comfort or solace would be appreciated. Thanks.
Went and picked up a big horse-sized syringe and some better fitting clear tubing this afternoon. Thanks!
Actually, had enough air in it to fill a balloon. Got home too late to accomplish anything last night. Will start over and bench bleed the MC and go from there. Thanks! Suppose I should have mentioned this is the Gremica mc ('05-on).
Will give that a shot tonight! Thanks!!
