theboo
39 -
Hi i have seen the same pant they look ok im sure trials uk do them
Rode a couple of trials over xmas, one went fine the other was over almost before it started rode a couple of sections and revs stuck on t around mid point, stopped the bike ran it a bit again and the same thing again, throttle fine,with a touch of play, stripped carb the pilot jet was almost solid,not dirt though ?? ,put it back together, i did nick the fuel pipe so had to cut a bit off, popped a new plug in and the bike kicked first time but failed to tick over without a touch of throttle,i did an oil change a couple of weeks ago ,and ive noticed its coloured up a little already any idea,s, someone suggested crank seals,or an air leak ???
Hi seals have gone gave them a really good clean and then pumped a couple of times and oil showing, clutch is odd at the start of the day clutch not fully engaging so i alter the lever a little but towards the end of the day i have to let the lever out again,
South to north would be best
Hi can anyone recomend anyone in yorkshire who service,s forks, seals went today require newseals etc, plus have a slight clutch problem thanks
i know the shock from a 125 fits
trials uk had one in have a look on their site
hi i would go through every thing incl carb airbox take side casing cover off, always worth adjusting pressure or standing further away when jet washing, hope all becomes well
i remember seeing a steve colley vid and he said he could only make money out of doing his shows
hi i bought the lwb model a few months ago ,its worth comparing dealers prices
hi what was the new format of the sections
regarding bou being smoother did you notice that his minder did not always go to a high point to mind,
we saw jacks crash and thought ****, just watched it again and breathed in even harder, he did well to get back on, good video,s
what a great thing to do
