rick1
81 -
Disappointing, last nights documentary had no mention or video on the sport of trials. The general population will not make any association to this as a sport. Also, just like seeing a trials in person versus on film, TV just doesn't due their act justice...as Howie pointed out...video is on youtube if you haven't seen it.
I have watched the coverage and see one issue. There has been no reference to the sport itself. The general population is not making the connection to the intended purpose and use of these bikes. The bikes are being presented (by the judges and host) as "stunt bikes" not competition trials bikes. Hopefully the Hollywood coverage will have some background documentary showing Pat in action at a National or some other trials event.
You da man Dan. I also switched to synthetic ATF, which I never used before, maybe that is part of the chatter issue as well.
Hey all, I completed the clutch mod and love the results, with one exception. I find there is a lot more clutch plate chatter. Have others who have done this mod found this to be true or did I miss something in the mod instructions?
My god there is someone out there who is as annul as I am. My wife and son tell my buddies that I "floss" not wash my bike. A couple things I do to my Beta. 1) I spray the entire bike down with Simple Green (full strength) and let it sit for 10 to 15 minutes or so. 2) Depending on riding conditions (if it was wet and even mildly muddy) I remove brake pads front and rear and clean them with a Scotch Brite pad 3) I wipe down the bike with a sponge and more Simple Green. This is where I usually find broken, bent or missing items. 4) I never, ever use a pressure washer. Don't need it, see item (8). 5)After rinsing bike down I take the bike for a spin to fling all water off chain (and heat it up), rotors etc. 6)Spray the chain down really well with WD (Water Dispersion) as well as all shock linkage and other bike joints. 7) I use a Scotch Brite pad to clean off rotors and brake pads (when removed). 8) I use a good quality car wax every few months to polish up hard to reach places and spots that get muddy easy. This does an amazing job of keeping mud and dirt off making it easier to clean like hubs and wheels. At one muddy ride this year my buddies were baffled at how my wheels stayed clean while theirs were a mess. 9) I always remove ignition cover after washing and spray with WD. Don't throw away old tooth brushes, they are great at getting crap out of places you can't reach, like the carb. A brass wire brush works great at clean crap off the chain.
The NETA (New England Trials Association) has been doing this for the last few years. This year we have 4 two-day events on our schedule. There are a number of benefits. One, as is mentioned above, the economics of one trip for two events. When traveling 5 - 7 hours to get to an event it is certainly more worth while if you can ride for two days. Two, for the event host, it is not really any more work to put on an event two days than it would be for one. In fact if you do it smartly it takes very little extra effort. For instance, using white section ribbons instead of red and blue allows you to run some sections backwards on the second day or quickly modify a section for the second day. Thirdly, all the administrative paperwork (AMA insurance , sanction, etc) is done once. Fourth, checkers seem to be more readily available especially on the second day. Fifth, its a great fun weekend. Folks hang around camping, bull****ting and just plain having a good time. Our club has found that more riders tend to show up if the event is done on a non-holidy weekend. In the past it seemed to make more sense to have it on a three day weekend figuring folks would want the Monday to drive home. As it turns out people seem to be fine with making the drive on Sunday night and I think a lot of folks already have family plans on the holiday weekends. It really does work out well..........even when you have three days of rain like we had at our 2-day last weekend.
The design is good just poorly welded. As Kinell stated, have the gussets welded up with a nice long bead and you'll be good to go.
I have done the carb mod on my Beta's (adjusting the tangs) and it has always worked perfectly as described. The problem I am having now is the hose coming from the float bowl spits out fuel when I lean the bike to put the side stand down or when I take the bike off the side stand. Essentially, any time I lean the bike to one side or the other it spits out fuel. Any ideas?
Brian, we are in Vermont. All the New England events give out trophies with motocross guys on the top. We thought it would be cool if we could locate a trophy topper that had a trials bike instead. Motofire, we actually gave out Maple Syrup with every trophy about 5 years ago, but at about $40 bucks a gallon right now that won't be possible.
Does anyone have a lead on where you can get a trophy top that actually has a guy on a modern trials bike versus another one of those dumb supercross / mx guys? I would even settle for a vintage trials guy.
Exactly what I have done for years and seems to work great and my chain and sprockets last as long as any of my fellow riders. I also don't hesitate to lube between loops during and event. Also I take the chain off before washing the bike. Also does a great hob of keeping your spockets clean. Doesn't have all that sand and grit built up to act like a grinding compound and wear everything down quicker.
There are a couple of New England Trials Association (http://www.newenglandtrials.org) events that are in the 2-3 hour range from where you will be (Meriden, CT, Brimfield, MA and Northville, NY just under 2 hours). A few others will be in the 3 hour range. Not bad considering my closest NETA event is 4 hours. There are also events in Western, NY that may be a bit further to drive too.
My job will be taking me to El Paso several times over the course of the year. I looked but couldn't find any trials activity in this area, is there any????
I couldn't agree more. I have tried ATF twice with horrible results. I have been using Mobile 1 synthethic for some time and find it works great. Being more readily available and cheaper I tend to change the oil much more frequently.
Holy Smokes! you may want to consider a new tire too. I don't think I have ever seen a trials tire worn down that far.
