martymc2010
13 -
Thanks guys i'll get one sorted. Just while we are on the topic any tips on bleeding the rear break????? Marty
I have recently bought a 06 Rev 3, Im in the process of bleeding the rear break. Can any of you guys tell me if there is supposed to be a resivoir in under the rear mudguard, as mine just has the hose with a bolt in the end. Will this mattrer or would i be best with one on. Regards Marty
Thanks guys i'll give it a go!
I have tried the water on hot disc's it works great thanks
Rear Michelin Tubeless Tyre Out Of Shape
martymc2010 replied to martymc2010's topic in General Trials Talk
I've been using away at it but when running low pressures it would rub against the chain tensioner at the out of shape part. on the stand from now on! I'll try pumping it up hard cheers. Marty -
Hi My rear tyre seem's to have a section that is out of shape. The bike has sat for a while with the wheel flat will this have caused permanent damage to the tyre? Marty
Maybe a silly question but does that mean you have sharp brakes for good or does the procedure need to be repeated?
Hi I need a little help with my clutch, when i pull the clutch in it still wants to go untill i give it a rev. i have been messing about with the adjustment, walking beside it with the clutch in and adjusting as i go but still connot get it to stop. Any ideas??? Regards Marty
Thanks, It worked!!! I kept cracking the lever whilst tapping everything untill the bubbles stopped and the fluid scoots out of the resivoir, still a little spongey and holding a little but going to take a run anyway. cheers
Thanks, sounds like it may not be worth the hassel at the moment but i might look into it at some stage. Marty
Thanks Ill give that a shot
Hi I have been trying with no sucess to bleed my front brake after taking it down to free up the pistons. I have tried it with syringe pushing the fluid from the nipple up to the resivoir, also left it all night with the lever pressed in to let gravity do its thing still nothing! Im letting it sit now with the bleed nipple removed,resivoir cover off, lever in and fingers crossed! Regards Marty
Hi Just wondering have any of you guys had a go at re-packing your exhaust, mine makes quite a loud "PUTT PUTT". Would re-packing be any advantage or would it still sound the same once done. Regards Marty
