wrmec
25 -
I got a new fan unit but it hasnt solved the problem, ( I tested the new fan on the slim chance that it was faulty but it worked. It shouldnt be the thermostat because it doesnt work when I bypass it and I put a new one on a couple of months ago. Is the only thing it could be the voltage regulater ( is this the silver box under the tank that is bolted to the frame?). This looks to be ok, is there a way of testing it, thanks
a couple of months ago i changed the thermostat on my 06 pro as the bike was overheating as the fan wasnt coming on. it was fine after that and all working as it should untill the other day when i noticed my bike was overheating again and the fan wasnt coming on. i bypassed the thermoswitch first and it still didnt come on so i took the fan off and tested it on a car battery and at first it didnt work, but then it started starting then stopping, then it started running pretty much constantly. i put it back on the bike and it wouldnt run (with thermo bypassed) i tried spinning it to try and help it to start but it didnt. my question is is it possible for the motor to be on its way out and work whilst on the car battery (it was intermittent when i first put it on) but then not when i put it on the bike. do people think a new motor would solve my problem. thanks in advance.
i have looked all over that website. i will ring the graupner company tomorow. thanks for looking anyway.
i have looked on ebay. none of them seem to be the 12v 500e.
hello. does anybody know anywhere i can get one of thes motors. i have tried cornwall model boats and two other model boat shops but they are out of stock and they wont be getting any in till may. thanks.
Thanks for that. I have looked on the lancs county website and the trials they do arnt to far away from me so im thinkin that me be a good one to join.
hello all. I have had my trials bike about 3 years now but have so far only been riding at my parents farm and recently i have been thinking about starting to do a few trials. i was just after some advide about the best way to go about it. from reading posts on here it appears i need to get a licence for the year and also do i need to join a club and if i do join a club can i only do trials organised by that club? I am in the south cumbria area also quite close to the yorkshire dales and north lancashire area. any advice would be much appreciated, i know there are some very helpfull people on here as i have been using the gas gas forum for quite some time. thanks.
Just a quick questio.. I have bought a brand new silencer for my gas gas off ebay. It was described as brand new however when it has come today it seems to have a dint in the back (as in the side that would go the wheel side). I just wanted to see if anyone knows if this is the shape of a new silencer or if I should contact the seller and complain? Its a silencer to fit an 02 to 07. Thanks
I have removed the rad and took the circlip off should the thermo just pull out? It feels tight.
thanks tazz229. i have done this and the fan came on so guess i need a new thermo. although the fan did sound a bit rough when it was running.
hello. i have a 2006 txt pro and the fan isnt working. i have tested the fan on a battry and it worked so i want to check the thermostat. do i need to remove the thermostat from the radiator to connect the two wires together or can i do it without removing it? thanks
i have a 2006 gas gas txt pro 300. can anybody tell me how to get to the thermostat, is it in the radiator?
hello. i have read a few things on here about testing the cooling fan using a car battery, could someone explain to me exactly how you do this please. i want to find out if it is my fan motor that is the problem thanks. my bike is a 2006 pro.
yes I think the problem is the fan has stopped coming on, is this likely to be the motor and is there anyway of checking this? Thanks
