leeross
25 -
What would be involved in converting a road version tiger cub ready for trials? Is it cheaper to buy a road tiger cub and convert in to trials trim - or just buy one already modified off a well known internet auction site?
what do you think about having a bike with or without matching engine/frame numbers? what difference does it make?
Am looking for a pre65 project bike, Nothing too fancy just an entry level bike that doesn
what is the ultimate pre65 bike? bsa etc
Top man Blocky you were right. Sorted the locknut out and this fixed the problem. Cheers!
where is the clutch adjustment inspection cover? do i pull the gear lever off and then pull the whole left hand side casing off? It has worked in the past. when pulling the clutch it was a realy stiff so i put a new cable on since then the problem began. Have i pulled the arm up too much?!
Clutch not working on Fantic 240. I can move the clutch arm up and down freely with hardly any resistance? All gears seem to select properly. when you put it in gear it wheelies off so the clutch aint slipping!! its just when moving the clutch arm up all the way nothing happens - bike wont stop!.
Problem solved. checked timing, cleaned carb, new plug, new (thick) base gasket, new head gasket - now runs like a dream!!
when revs are dying down almost back to idle there is a knock/pop (metal to metal sound) coming from the head. Sounds as if the piston is hitting the head?! taken it all apart. Piston/Rings seem fine. No play in big end bearing. Slight play with small end bearing when you move it side to side but thats normal so im told. checled carb/exhaust all seem ok. When you rev, its revs up fine. Poping/knocking only hapens when revs dying down. i run 75ml castrol tts per 5 litres unleaded. Help.
Where does the ONE wire from the centre of the 'rubber' kill switches go? Live(red) or Green(trigger) Is there no earth on these kill switches? thanks
Are you allowed to use tubeless rear rim/tyre in twinshock events? ive looked on the ACU handbook but cant see anything in there. Is it worth the money/effort to respoke the rear to run a tubeless rim/tyre?
gasgas 250 or Beta Evo 250?? what would you go for and why?
where are the engine/frame numbers located on a gasgas pro?
ive got some engine ice.. Not sure what coolant was in there before i bought the bike. shall i just top up with engine ice or flush the whole system. If so how do i drain the coolant and will i need to bleed the system? thanks guys
Which way should the fuel tap be poynting for off, on and reserve on a gas gas 250 pro. also how do you check the water?
