kayloe
43 -
Thanks all sounds like a weekend in the Garage. cheers kay
Nigel, Do you mean take flywheel weight off? cheers kay
Thanks Guys, looks like i need to do clutch mod first then maybe slow action throttle but i love the way the power is delivered now its just that slow clutch throttle combination i need to work on i think. Cheers kay
Any help please, I have an Evo 290 2009 and has a weight fitted to the mag which was on when i purchased the bike. I love the bike but when riding slow tight stuff i find it snatchy and easy to push the front wheel away. Gearing is 10/41 so previous owner dropped front by 1 already. How can i smooth it out when on the slow tight stuff? drop to a 9 front?? could i ride off the clutch more then? slow action throttle i dont think would help?and i love the power anyway. Would the clutch mod help and maybe remove a couple of springs? Please help before i move over to the dark side (gasgas) cheers kay
Thanks , mine was a 2010 fender although the bike was 2009. The break was low down towards the airfilter area and it was a real clean break with no plastic distortion at all. Bit crap really considering the nature of the bike. thanks kay
Hi, Just snapped my first rear fender ! grrrrr how much! Anyway i have been offered a 2011 fender a little cheaper than 2009 fender, is there a differance? will all years fit? many thanks Kay
Simple thing guys, anyone know plug gap for 290 Evo cant seem to find info cheers Kay
Hi, Just about to do the first oil change on my 2009 290 evo. Does anyone know the torgue wrench setting for the drain plug. cheers
Hi, Just changed over from a gasser to Beta 290 Evo, just wondering when starting from cold do you use any throttle or leave alone just with choke on. many thanks Kay
Thanks Jon, i will check this out later and see if it matches, the photo i was after was an under the tank picture of how the coil and wiring sits. Mine seems a mess and was obstructing the tank slightly so needed re dressing. many thanks Kay
Hi all, Just removed one of the pins to resolder as badly corroded, unfortunatly all the wire came out the plug and i dont know which they go back in? they are numbered on the back of the plug. I have a black, grey, thick yellow and thin yellow. help please
