I looked up the old bike test from Trialsport, when the yellow Guanaco came out the frame geometrie and the steering angle was changed stated in the bike test from 1980.
When SWM changed the fork from Marzocchi to Betor and cutted away the mudguard loop (which was in 1981 / 82) these were the "only" differences statet back then in a short message in Trialsport (As I found so far), likewise the change to the blue color scheme this was only mentioned once as a favor due to Pernod which was their main sponser !!!
Then again with the Jumbo the complete frame was new developed and also the steereing angle altered, (a story bout the development of the engine and frame in Trialsport of September 1982, issue 78), the foot pegs were placed 5cm to the rear and the complete center of gravity was also placed 2,5cm to the rear, the front therefor feels much lighter on these later bikes.
Anyway with the fork swap from Marzocchi to Betor the complete steering angle was too changed as the dimension and also the overrun is much different between these Fork models.
As I figured out even between Betor forks for Bultaco and SWM.
Oh the question of questions, ... well I have made good experience with PDL Dry Lube on teflon basis. But I don't know if its sold in the UK?
At least were I live quite priceworthy as in the same price range as Castrol even cheaper then Bel-Ray or Yamahalube, you really don't need as much to apply as with common chain lube it "sticks" very good too. Even in very dirty environment the chain stayed clean so far and we have quite a lot mud and sand here.
The only disatvantage ... you need to get rid of any chain oil or grease that was pured/sprayed on the chain before, otherwise it will not stick to the chain.
Just a guess ... as You have installed a Mikuni carb to the engine there might be an issue with the carb to intake manifold connection, ( had a fitting problem too while mounting a DellOrto instead of the Bing ). May be the connection might not be not enough thight... I would check the connection, not only when idling but too when rev. up, just to sure ...
I can't imagine they cast different legs so I'd assume it is the tubes that are a different length. As pointed out in the above post your frame looks correct for a 190 as does the bottom clamp. What I can't figure out is the 190 tubes shown in PSchrauber's picture as they don't look like they are from a 190... The knurled part looks as though it would sit below the bottom clamp but maybe it's just an illusion. The tube in the bottom picture looks more like a 190
To the fork that came from a 190 I can only relay on the previous owner, I never saw the bike just the pair of forks and yokes. For me the main points were the length of the stanchions and the internal parts. After a short play of questions and answers my needswereclarified. Who knows what happend with the bike and through how many hands it has went.
But the bottom picture shows one leg of my 199b, here I am confident and I have all ressources from the build in the end of 09 in 1981 until it was sold to me, (I' am the second owner).
There are a lot of nice places to ride in the Alpes. You will see spectacular views, climbs and downhills on trails which are demanding and sometimes scary when the route is just one meter wide and on one side it's going down really deep, and these "sections" sometimes seems never to end too...
I'am a great fan of riding there, in own experience do it the first time with some people which know the terrain and please don't do it alone. You really have to get used to it, the routes shown on maps doesn't tell you anything about the difficulty.
As a starter I would recommend:
Trial Area Alberto il Castellino in Brecia, Italy,
I personal have planned a trip to the Alpes in Piemont near the French border in September / October, which is a good time because most flocks of cows and goats that uses the mountains during summer time are then already guarded down, so there is no conflict with the farmers.
Then you have to know were it's allowed to ride and were not, it can be extremly costly if you meet the Policia Forrestale on the wrong ground.
If you still want to ride by your own and not use any professional guiding, have the bike road registered and insured (international green insurance card should be on hand, the police might ask), lights fitter, a working brake light, numberplate, speedo and mirror attached, ( this is for some of the trips provided by the ressources named above not necessary, look them and their offers up for more details).
Are you very sure about the size of the tires you need?
In Germany the bike has 2.50 x 19" front and 3.00 x 17" rear this size is available by Vee Rubber for the front and a manufactor in Asia were I have forgotten the name for the rear (front with trials knobbys and rear with a very trials like pattern).
The 50cc model was sold in some numbers in Germany, I guess at least 10 times as much then any 125 / 175 / 250 cc model, you saw this model quite often as a moped, ridden by teenagers on the street to school, ...
I habe tried some repair, a very expensive 2 component ( from Henkel ) which is used for car body repair, works nice but is black, of the look of the repaired plastic wouldn't ne so bad very recommended in my personal experience if you paint the plastic later.
The other method using heat and repair sticks/stripes works also very good, you only need a special blade for a torch- lamp or an electric solder unit as a welding device. But these method works only if you which kind of plastic you have and if there are repair stripes for this kind of plastic available. The method is to shape a V to both edges, then heat up both sides while simultaneously placing upheated and nearly fluid plastic from the stripe in between. It's like welding steel together, but only works with a couple of plastics not all kind. Should have a list of plastics which can be repaired with this method. And not to forget these sticks / stripes are available in some different colors too. The repair works pretty good as long as both plastic sorts the one of the part and the one of the stick match, otherwise the welded area will crack again easy.
It's possible that one or both of the tubes have a bend, or one of the yokes has a bend, and you might need to experiment a bit to fit the tubes back into the yokes exactly the way they came out.
To work out what is wrong, fit only one tube to the bike at a time and see what you need to do to get it to move fully into the tapered hole.
+1!
I would too recommend to check the stanchions if they are still straight before assembling.
Another hint, for getting the tubes better in / through the holes is to clean the surfaces of the holes of the fork clamps very well, (probably using steel wool).
And if you want to use the upper nuts to pull the stanchions up in the upper yokes be sure you have the nuts at least two or better three threads turned in, (just to avoid pulling threads instead of the stanchion ... )
in France: http://shop.brp-rotax.fr/en/2-parts (communication only in French, you get sometimes not the spares you ordered, but with a call you can get it sorted)
in Germany, Reinhard Hallat: http://www.rotax-deutschland.de/index.php/de/ (speaks German and some English, you have to call for parts and remind him to send them away after a week, as he is sometimes very busy (distracted))
Mmmh 57 teeth, not commen ... I recently ordered a custom sprocket too Wüdo make custom sprockets in every teeth number in aluminium, numbers ad pattern for fasteners as requested, inner hole diameter too even a recess if in need. Last not least the would even mill a recess in the srocket if you need. The aluminium sprockets can too be anodized in many colors.
Reallocating the condenser is not a real "must have" just replacing - if in need - works already very well, as most electrical parts don't get better with the age. A new condenser will be much more reliable then a over 30 year old unit that might fail just because it's got a little bit warmed up.
Anyway looking forward to follow another Sherpa rebuild, thumps up !!!
There is a nice black and white Bultaco, stationed in the Netherlands. It's a PUMA rebuild.
I believe as long as you do the "paint work" withcareandinaccordance with theoverall appearance of a Bultaco Sherpa involving all parts in the design scheme you can't do it wrong. It seems to me that all good examples in different colors still have a typical Bultaco Sherpa recognition value because they use the originallabels.
Frame Differences ?
in SWM
Hi Ross!
