pschrauber
Posts posted by pschrauber
  1. still waiting for apology or at least " I may have got it wrong"?
    Hello Mr. Dabster, why taking it so personal?
    There is nothing to apology, or getting wrong for my part.
    At first let us remember that any message that is posted here expresses the
    personal view of the author.
    Second as already stated from my personal view, the later headstead is an
    improvement, look under post #11.
    Third as mentioned in my personal view, the earlier headstead was difficult
    to mount and disassemble and could be bended while mounting. Bending
    a cold pressed steel component weaken it's structure. Look under post #11 too.
    Forth it is fact that after the bankrupty of bultaco, there did not exist any executive board
    or development division. The operation of the factoy was an offical social program by the
    goverment for the reminding workers there. The production run was controlled by the
    workers itself. There only exist an assembly, - no processing -, therefor there do not
    exist any kind of part's book and the later Bultacos Sherpas that where assembled had
    sometimes different technical equipments.
    Fivth, if there is no dokumentation of the work that was done, (here the production run
    of the later bikes), it is incorrect to give a statement as an evidence when there is
    no prove.
    I always appreciate the friendlyness, commen sense and the regardful acquaintance
    in this forum, why are you so harsh, there is no need?
  2. FWIW my 340 also has the alloy one as does a couple of others that i know of. Dont get what the big deal is it's an easy enough item to make :chairfall:
    One of the best answers in this thread IMHO, had first to figure out the meaning of FWIW is. :thumbup:
    I do like to keep calm and to show confidence too and I dislike anything showing to be too keen to do well.
  3. The standard pressed steel bracket will break if the bike is ridden in any sort of reasonable competition, if it is not repaired the frame will begin to bend, the backbone bends upwards and the front downtube bends inwards and hairline cracks will start in the downtube at the bottom engine mount and at the junction of the top triangular gusset and the downtube. All the 199B bikes I have seen have had the pressed steel bracket, so I would really like to see a detailed photo of the late factory alloy one fitted with the tank off. When I have seen photos of some english bikes with them fitted I just assumed they were a comerfords modification.
    Cheers Greg
    Yep, totally right, to avoid any overstraining to the headstay it is necessary to mount the complete cylinderhead / headstay assambly together.
    Bending the headstay down for getting the engine better out of the frame is a bad idea, (you will overstress the steelplate, which later will cause that it cracks). Just unscrew only the two fastenings of the cylinderhead for getting loose the headstay is also not recommended, you can "wrap" the head.
    This is the problem of this kind of bracket.
    BTW:
    Why the headstay is not mounted to Mr. Michauds former Bultaco is a miracle to me.
  4. I haven't written / said that it is impossible that someone changed the design or the headstay.
    But as I know there is no offical parts book and no offical photo around showing this bracket.
    Nevertheless the aluminium bracket is an improvement, because you don't have to bend the steel one down or loose one
    head nut + one head screw to get the headstay detached for more space to get f. ex. the engine removed.
    Juast as a reminder: the bikes build after the bancrupty of Bultaco where somekind special because the executive board wasn't involved in the production.
    BTW:
    Some Bultaco riders don't even mount the headstay, (Here the T199B EX Fred Michaud):
  5. Read my post, the later 199b's.
    I have read your post, there was NO other headstay mounted than the one made out of steel.
    Maybe someone installed an other unit to Yours or one of the last reminding workers, - still employed in line with the welfare program that was initiated by the goverment-, that wrenched the last Bultocosbikes together from the remaining parts that where available in the factory was tired of searching and mounted what he found.
    If you have any doubts, ask Orlando Colander, he is one of the last remaining importer of bultaco
    motorcycles und parts and he is still in business too! -> www.orlandocalondersa.com
    Otherewise show me the part number ... there is none I know
  6. they were pants, which is why the later 199b's had the ally one.
    They are out of steel, look here, detail left, mounted right:
    %5C%5CMISTER-BINAER%5CServer-Anwender%5CPatrik%5CBultaco%5C2010-12-12%5CDSC07872.JPGBultaco%20Limaseite%20links%2003.jpg
    Just work fine?
  7. for my sherpa 350T 199A
    Why do you need a stronger headstay?
    What happend to the one you have, did it break or do you think it will break?
    The standard one that came with the 199A is just fine IMHO.
  8. ·
    Edited by PSchrauber
    There is NO real good clue to solve this problem with the standard
    plastic tank, this was and has always has been a problem.
    The vapors of the gas will always go throuw the plasic and therefor
    bubbles wil occur to the paint of the tank and to the decals.
    For the Bultaco you can opt to a fiberglass tank, that just look the
    same like the original one, you get them in Spain. They are hand
    made so be prepared to pay more than for a standard one, (around
    twice as much, without paintjob.
    Otherwise, you have to drain the tank after driving and leave the
    tank cap off for storing, do this always after driving, don't store
    any gas inside the normal tank then the decals and paint will hold
    a little bit longer, this doesn't cure the problem.
    In the US there is a company that can seal plastic the only and
    proper way, this solution was posted in KTMTalk forum a while ago
    but it isn't cheap either and the procedure is nothing for home
    work because the chemicals are very dangerous and you won't get
    them as a privateer.
    It's a fluorination barrier treatment they do.
    Here is the link if you interested in further information:
    http://www.thecarycompany.com/containers/plastic_bottles/fluorination.html
    BTW:
    Happy new Year!
  9. ??? => The numbers are printed on the bearings / seals take these numbers
    If they got lost, ... this is the specification of the ball bearings for the rear hub: 2x 17x40x12mm
    The front hub bearings are: 2x 12x32x10mm, take SKF INA, or whatever you get as an industrial standard.
    To the seals, (Simmerringe in German, because they where invited by Mr. Simmer in Germany): 2x 17x32x10mm.
    These bearings and oil seals you get nearly everywhere where they sell bearings and oil seals, nothing special.
  10. If the bearings are OK You can still use the old conrod,
    BUT:
    If you turn the conrod by hand and the bearings feel kind of harsh while moving (difficult to explain),
    not smooth and without any feelable resistance, than it's time to exchange.
    Damages to the bearings can emerge just because the engine had stood too long without being driven.
  11. Standard for the betor forks is 180 ccm of sae 30! each side of course.
    Sprockets, front with 11 teeth is OK = standard, back, yes standard is 39 teeth.
    You can get parts for clutch de- and reassambling thru Bultaco UK for example.
  12. ·
    Don't know where or in which events you ride but "I Think" the flat slide carb is illegal in AHRMA events.
    Alan
    I think you will find they are using the PHBL dellorto as the flatslide is illegal for their competition. I have a PHBL on my 325 and it runs fantastic, 36 pilot and 116 main. My dellorto is a gasgas genuine spare part so you can run a gasgas throttle cable and throttle.Hope this helps.
    Cheers Greg
    :agreed:
    Both of You are right, the VHST carb would be illegal by using with the Bultaco in a AHMRA events. I just looked up the rules here in Europe, (Germany), here it's the same. So this carb would work but it's not allowed to mount him, OK.
    Actually I got my eyes to this model by a page of Todotrial where this model is shown exactly for classic bikes as I understood.
    BTW: My understanding of Spanish is very very poor, here is the text:
    "También los famosos Dell'Orto están ya disponibles en TT Shop. Ideales para restauraciones y preparaciones de clásicas, ya que hay modelos que se utilizaban en la época, como el PHBH 28 o el PHBL 25, con lo que superan las verificaciones técnicas de las competiciones de trial para clásicas. También está disponible el novedoso VHST 28 mm de compuerta plana, que mejora el rendimiento de los clásicos de compuerta redonda."
    But maybe my enthusiasm has made me blind for the real facts. :)
  13. The carburator of my Bultaco Sherpa T 350, :wub: model 199b is retty
    worn out, the slider rattels around, a lot of whitchpee has left
    its tracks inside the bowl and the small plastic filters are cracked.
    Time to get a new carb.
    I have seen some Bultaco Sherpas, 199A and 199B models in photos from
    the Spanish Zona Trial and Todo Trial sites, fitted with
    Dell'Orto VHST carbs. Has anyone did this here in the forum too and
    have the spec's for jetting?
    This is the italian atomizer in a picture:
    Any recommandation or hints?
    Oh yes, it is a carb with a flat slide!
  14. Another option would be to get a manufacturing company to take a lot of points on a cordinate measuring machine and then have an Engineering college make a CAD model (there is a shell type tool in the CAD systems to make the model bigger to allow for shrinkage). They can then print a sand castable 3D model. Take to a sand casting company and make the casting. You still would have to have it machined. I'll take a look at my new 199B when it pick it up. Below is a pretty cool do it youself prototyping method. Might be more appropriate for like side panels or headlight plastic. Also we use some urathanes that have a much higher yeild strength than these materials (just keep your feet on the pegs and you wont have any problems!).
    http://www.alumilite.com/HowTos/MoldingSteeringWheel.cfm
    Sounds nice and great too, after my casting sidecases in aluminium medly.
    I bought a pair of used sidecases the other original one's that are damaged i have now sended to a special company that will repair them, (very expensive).
    But if You get replicas out of plastic and they work, (don't forget the kicker, the clutch and the gearing locations on both sides). I am surly one of the first that will buy a pair of you. Just send me an PM when got any good results.
  15. If You have a new carburator check the following parts:
    - position of the needle
    - same jet size
    BTW cleaning the carburator:
    works best with a ultra sonic bath, any good motorcycle shop should have this equipment,
    only some
  16. The best way for aftermarket is to make a cad 3d model and make permenent mold castings. The tooling would cost about $12,000 US Dollars per side compared to $40,000 + per side. This method is the most cost effective method up to 10,000 parts. The permenent mold casting is gravity filled instead of forced injected with a plunger like a die casting. The perment mold would have much less porosity (high degree of pressure tightness) and higher strenth than a die casting or sand casting. Vacuum impregnation might not be required for the clutch cover. It's also possible to build a family tool for around $18,000 but I would not do that because the magneto cover would sell like hot cakes or they could mess up the mold. Cost would be under $20.00 each including machining and polishing.
    If you just needed one part you could do it in your garage like this.
    http://virtualindian.org/3techcasting.htm
    Thank You for Your posting,
    as already mentioned from You and me too the costs are to high for just 10 or 20 cases each side.
    The costs for a die cast are too high. So I tried a sand casting, which should have been done by a company that is specialiced in casting prototypes for the german car industry, Volkswagen and Audi, the quality is very good, they use a special aluminium alloy that is very strong also if not casted under pressure. Also the Volkswagen group cannot effort a diecast form for each protyp they need. But the problem is the shrinking of the metal when the case is casted and it cools down, (about 4% in each direction)
    The side cases have a tricky form and that makes it difficult to calculate and produce a positive form. These costs making a 3D model crop the model and then the milling of a casting mould for each side would cost around 4000
  17. ·
    That is one of the very late Italjets, a 1984 model I think, (but not sure). The last twinshocks around 1985 or 1986 had blue frames and a red seat.
    Before they looked like this, third generation, a Piuma with Betor forks:
  18. Has anyone tried fitting a flat slide Mukuni 28mm carby to a Sherpa T? I ordered one and would like to know what to expect. Anything to watch out for as far as tuning, throttle control, etc?
    Not so far, I'am also searching a replacement to my worn out BING, (the slider shutters around inside the carb, slider and sadly the barrel of the arbbody is worn out in the lower section. I know that a Dell'Orto VHST 28mm will go too and should improve throttel response and gas consumption.
    This is discussed and shown in Zonatrial in Spain:
    Superpreparaci
  19. Just got the reply from the factory,
    it is not possible to take the original sidecases as a model for sandcasting because the new cast will shrink during cooling down - around 4% of the original dimension - this will not work because of the rods for the clutch, the gear and the kick starter ...
    Their solution would be a 3D scan of the cases, then they would crop the electronical model to the calculated bigger dimensions that are necessary to compansate the shrinking while cooling down. They would then milling a castingmodel of the 3D data. This model will then be used for the casting process.
    The costs: 4000
  20. I suppose another alternative which i have used succesfully in the past is a product that is sold over here called Lumiweld. ...
    Haven't heard about that brand or that possibility yet, I will give it a try. I just have ordered a set with 10 sticks, (hope this is enough). Will keep you informed how it worked out at the end.
  21. ·
    For dents with internal cracking, push dents out from inside then weld repair on the inside
    @feetupfun: Thank You for the hint, one question:
    If I will do so (pushing the dents out, the cracked parts will probably brake off, this is no problem? :unsure:
    weld a repair and machine back.. they 'll be as good as new.
    @feetupfun, @totalshell, Thank You for the hint, one question:
    The side cases are die-casts so welding is difficult are there any hints which kind of weldingmaterial I should use, welding should be done with WIG? :unsure:
    As You see in my reply:
    I do feel a little bit unconfortabele doing so because these are the only one I have, If I would have spare a try out is no problem, (I like to do some experimental stuff if it is reversible or there exist a second plan. :)
  22. Hi,
    I have a Sherpa 340, which I'am rebuilding, the bike is in a let's call it good condition beside of some parts.
    One of the main issues are the side cases where some alumium of the embelms are broken off, (can be fixed with
    fluid / kned metal). My concerns are the impacts that are visible and caused cracks on both side cases.
    I searched already E-Bay, dealers worldwide for gettimg replacement cases, but did not found any.
    Here are some pic's of the cases outside:
    Now the problem inner sides, (the cracks to the clutch side are not so good visible (only one of three!):
    As visible the case structure on both sides is weakend a lot.
    I could by a second bike as a sparepart would work with a 199a to 199b, but this is not my first intention.
    I have sent both cases to a manufactory that do metalcsatings and have also a machining center, (they do gearbox castings for VW here in Germany), to give me an offer.
    The casting will be a sand castings, no die csating because than they have to make forms which should be extreme expensive.
    To remanufacture only two for both sides will be expensive too, if there is a smaller production run the costs will be go down,
    anyone interested? (I don't want to make any bargain, you would get them for the money the manufactor will have + shipping.
    If the remanufacturing will be to expensive, (I'am afraid it will be), do you have any good hints to get the side cases repaired?
