Posts posted by pschrauber
5 hours ago, blow_away said:
One rule I try to adhere by is to be invisible. Don't leave the garage door open when washing the car/mowing the lawn/whatever. My van doesn't have any stickers on it. Keep your trailer out of sight. Passersby don't know what I've got, and I like to keep it that way.
To stickers I would suggest instead of any motorcycle brand to put also non or some big ones with the sentence "Pipe Cleaning Service" on the sides, that should keep off easy
Guns ... that is not the best solution ... can get you in trouble.
Best solution is a road registered bike and an electric driven rolling gate or door because:
easy to close and open just by key or transponder, in holidays you can even shut down the electric supply,
very difficult to open if closed without electricity, if you try it it will get noisy.
I never heard of burglars trying to open electric rolling gates section gates and.doors of course also standard garage gates, but rolling gates ... my advice in this department beside good insurance.
Edited by pschrauber
Alternative could be a Dell'Orto PHBH 26 BS, the a bit more modern one with air screw and idle jet nozzle.
At leat works great to my 242, another carb but expensive would be a 25mm SmartCarb* but that is costly.
I would not use an AMAL again unless the slide issue is not solved, (the AMAL used the same material for carb bod
and slide which causes super much friction and leads very fast to rattling slides so worn slides and carb bodies!)
The silde should be made out of the softer material the Body should be made of the harder material, so the slide wears
and not the carb Body, thus the plated and hardened slides are not such a good idea because in the end you will have
a proper working slide but a worn out carb Body ...*SmartCarb has no jets which is super nice in handling and if you ride in very different climate and hight situations.
Easy peasy…
Get them insured and then you know, trials bikes can get road legal then a standard Vehicle insurance and you are save, stolen registered vehicles especially motorcycles are of much more interest to the Police then leisure vehicles. If you insure several bikes you get a discount too, thus I have to pay around 20 - 40 € for one bike in insurance, the tax for each bike is higher...
A standard insurance for non road registered bikes like MX, trials is around 180€ a year for one, if you get a discount for several I don't know.
Oldtimers (over 30 years old) can also be insured without road registration which is also 180€ a year (The bike was made: 1980, has 22HP, worth is evaluated with 7.500 € of replacement value in a total loss).
sentence issueIt takes so long to get them dry? We have also very much rain (beside this year) and soaky ground, anyway I dry them in three to four days using this method:
- I take out the inner sole, there is one that is sometimes tricky to get out, but to take them out while drying that is very important, (it can be too replaced by a new one too. if the odor isn't good anymore),
- Then I let them stand and keep the upper part wide open so maximum air can reach inside, and I start to do so immidiatly and store them in the Trailer
that's all I do and so far it has worked very well. -
As B40RT posted, try to get everything really sound, from engine, to exhaust, also airbox and air filter as these tend to be restrictive,
A rebuild of the middel and end silencer is a good idea improve engine Response a lot and quite expensive if you can't do it by yourself.
If the engines does rattle a bit and got a bit tired, a new conrod a rebore with a custom made next size piston is also an improvement for riding in general and an investment which emty the wallet easy.
Too smooth running cables with teflon inliner, good brake pads with soft paddings, good rear shocks that suits your weight.
Fork stanchions are they really straight or a bit off, if a bit off for better action you can let them straightened and rechromed and Special polished improves Action and you will have less stiction too, then you might too mount HFS air cartridges to the Forks to improve dampning and Rebound.
Last not least an electronic ignition.
Opel Signalgrün is matching that the original Italjet color very well.
I that color for repairs to my JT50 and two 350 Piumas I had back in the day:
rattle can 2K color:
https://www.123lack.de/2k-spruehdose-opel-signalgruen-308-autolack-glaenzendrattle can standard 1K color:
http://www.safonov-autolack.com/spray/autolack/dupli-color/dupli_opel_308_signalgruen_1973-1977_spray_400_ml_7-0260_i192_25383_0.htmor complete cans:
https://www.123lack.de/2k-autolack-opel-code-signalgruen-308OPEL was part of GM back then so therefore the
1 hour ago, 2stroke4stroke said:
Under Newton's Third Law it makes no difference to the action of the spring but it is normal to put the tighter coils to the top to reduce unsprung weight (slightly).
Just fork springs, to shock springs I wan't the thighter coil part of the spring being mounted as much up as possible so that debris can't build up between rear shock spring and rear shock body.
Rally black with satin dull finish from rattle cans is what you want to put to the fork legs if you want to keep it original.
IMHO that matches best, just a thinner coat, no prep, no base coat, … that is the original Bultaco paint jop to all metal pieces painted black,
and to blue not better either, the orihinal blue paint did chip off like hell.
On 25.09.2018 at 7:50 PM, nhuskys said:
Interesting that Italy allows small plates, but when Enduro GP round is there....it's the only round on the race schedule that requires standard full size motorcycle plate on competition bikes.
Depending the bike and year of first registration I guess, as the corpo forestale was pleased when I met them last time in the mountains in 2016,
The corpo forestale is a police belonging to the Carabinieri and responsible for forest, mountains and other nature area … -
As I know in Spain it is like in Italy so:
- number plate
in Italy can be a small one or the number directly attached painted to the rear fender,- lights front and rear,
- a horn,
- a mirror, a folding unit is sufficient!
In Gemany add:
- brake light rear and to modern bikes from 1990 at the front too,- lights with high, low, and parking lights!
- standard number plate,
- flashlights aka turning signals (if the bike is not made before 1962).
On 07.09.2018 at 12:41 AM, section swept said:
Thanks b40rt I was aware about the Continentals using those makes, but it is the ‘works’ bike that I was particularly interested in?
They where all works bikes and custom made so non of them where similar in build, the early Franke owned where 200cc models, later they had 250cc. Not only Franke rode them also Felix Krahnstöver from Celle.
(Felix was 11 times German trials Champion, wrote a very good book about trials riding and was founder and editor of Trialsport now the oldes Trials related Magazine).Anyway here some pics, the first is a 200cc I thin which is very much likewise the Franke bike photo taken from beginning July in Lüneburg:
Another one, from Brockhöfe in March 2015 or 2014:
Also very interesting a Hercules with Sachs engine, they are kept in much original shape here
A good article is in Trialsport #501 where a complete portrait of Gustav Franke and his Zündapp is reported in Trialsport Magazine as he turned 80 on 4.12.2017,
The Zündapps where very modern in their days, the engine had very improved porting, carb was with Bing with accelerator pump, (Bella scooter)
the fork had already hydraulic components with progressive dampning, then the super long swing arm and steep fork angle surplus the light weight. -
You might look up ebay worldwide especially US, UK and France for forks.
Also Craiglist in US, Gumtree in Britain and Leboncoin in France.
I like to work with what I have and when the stanchions are too shiny!, pitted with rust and also just a little bit bent (a few mm) or not straight.
They get a new chrome finish and get straightened. There are companies in the UK that do that. O sent mine to a company in Germany:
Wissing Hartchrom in Vellmar
They are professionalists in hardchrome stuff from propellershafts for vessels to hydraulic shafts for digging maschines.
Costs are not higher then a pair of NOS ones.
38 minutes ago, turbohead said:
a total loss system with a small NiMH battery somewhere on your bike, usually keep police and MOT-people happy.
Not, working the battery solution is already used for the flashes for the techical TÜV test every two years.
To any other riding with roadwork, the task is light's, stop light and horn in use, this can be easely looked up and tested by every police or forrestale as light's have to be switched on on the continent during the day!
Trial bike in winter
in Beta
Yep would get a antifreeze tester and test to how low temp. the coolant can go. The other method would be to get the bike from one warm place to the other to put some moving blankets around it, as a two hours route will not cool it down too much in a closed trailer. When it is an open trailer I would definetly mix the coolant to be valid for these low temperatures.
