woodbutcher
60 -
TRY WWW.BILLETPARTS GOOD QUALITY , FAST SERVICE
TRY - WWW.BMZ.FR -FRENCH SHOP
NEEDLE JET SEAT WILL TAP OUT FROM BELOW (TOWARDS SCREW ON CARB TOP) WITH SUITABLE SIZED PUNCH OR OLD DRILL BIT
COTA 172 SAME YEAR AS YOURS POSS. HAD FULL SIZE WHEELS (21X1.4 OR 1.6 + 18X1.85 RIMS). COTA 247 LATER YEARS . COTA 123 + 200 ( INCL. MONTESA/HONDA 123 + 200) 1980 - 1984
50:1 FOR FUEL MIX 29H DENOTES MONT/HONDA 200 ENGINE - 64MM BORE 28H SHOULD BE 125CC - 54MM BORE 200CC TOP END WILL FIT ONTO 125CC
IF YOUR TALKING ABOUT AIR COOLED MONO YELLOW/GREEN OR WHITE/GREEN BIKE THERE SHOULD BE TWO PLASTIC CONNECTOR BLOCKS FOR WIRES COMING OFF CDI UNIT . SMALL BLOCK HAS 2 WIRES 1 GREEN + 1 WHITE . GREEN GOES TO HT COIL SO TRY THIS ONE .
IF YOU'VE GOT ROTAX ENGINED APRILIA THE PIPE ORIGINALLY HAD 1 WAY VALVE BETWEEN ENG. + CARB .IDEA WAS EXCESS/UNBURNT FUEL PUSHED BACK INTO CARB BY ENGINE COMPRESSION HELPING BIKE TO RUN CLEANER + PICK UP BETTER FROM IDLE
RE. DESIGN FAULT . - THE PROBLEM WITH THE GEARS IS THAT WHEN THE CLUTCH CASE IS REMOVED THE SHAFT PULLS OUT WITH IT ALONG WITH THE TWO RATCHET GEARS + 2 WASHER /SHIMS .THESE ARE THEN OFTEN ASSEMBLED INCORRECTLEY LEADING TO THE KICKSTART GEARS BEING MISSALIGNED AND NOT MAKING FULL CONTACT WITH EACHOTHER , LEADING TO GEAR TEETH BENDING + EVENTUALLY SNAPPING BITS OFF . EVERY BIKE I HAVE WORKED ON WITH CORRECTLY SPACED GEARS HAVE HAD NO PROBS . AND ALL DAMAGED GEARS WERE BECAUSE OF INCORRECT SPACING ON REASSEMBLY .
MONT/HONDA 200 + COTA 200 KICKSTART GEARS ARE THE SAME THRU 1980 - 1984 . ONLY CHANGED FOR 242/304/307/309/310 ALONG WITH KICKSTART SHAFT + KICKSTART LEVER . STILL AVAILABLE NEW FROM SPAIN + FRANCE
KICKSTART LEVER OR KICKSTART GEARS ?
210mm or 8 1/4 inches between centres , but it does not look like orig. part .
WILL MEASURE MINE TOMORROW + SEE IF IVE A SPARE
TRY 5W OIL IN DAMPER SIDE , USE DAMPING ADJUSTER FULLY ONE WAY -ve THEN FULLY ONE WAY +ve TO SEE IF YOU HAVE ADEQUATE DAMPING ( OR ANY DAMPING WITH 5W OIL) . IF NONE DRAIN OUT AND FILL WITH 20W AND PUT 5W IN SPRING SIDE
JUST SEEN YOUR OTHER POST , FILL USING 5W OIL IN DAMPER SIDE ( ONLY ) FIRST IF NO DAMPING DRAIN + TRY 20W + PUT 5W IN SPRING SIDE
IN 93 HAND BOOK IT SAYS 260cc BOTH LEGS ,BUT MENTIONS 2 X DIFFERENT GRADES OF OIL 5W + 20W . WOULD THINK 5W FOR DAMPER 20W FOR SPRING SIDE IF THESE RUN SPRING IN ONE SIDE ONLY . IF DAMPER RODS IN BOTH FORKS USE 5W IN EACH .
