bondy
Posts posted by bondy
  1. that what i use,its fine
    hi again john thanks for that ive got a full bottel so happy days now i just need to find some where to ride it
  2. i run it on ipon semi/sin,dont use fully sin unless you rev it hard you wont burn the rich oil off witch will lead to poor starting
    70ml to 5L is spot on runs very clean
    nice one john i havant put anything in it since i got it from the shop shes just siting there in me kitchen sorry to pick your brains. ive got some ipon semi/sin/ strawberry will that be ok or would you recommend i diffrant ipon? cheers bondy
  3. :thumbup::thumbup:
    hi its john,no flyweel weight on the bike as it was mine,420ml putoline dextron 3(red) gear oil changed every ride
    bike has been looked after by me,i have over 20 years experience on gas gas
    hi john nice to know its been looked after i can tell. only reason im asking is because ive only had twin shock. im keeping the bike in the house ive only took her up and down the close lovley bike you have done a great job of looking after her as i will. this is why i need to know what oils you put in so i can do the same. what 2 stoke oil was you using? and what mix? roy said 75mm/ 5L the bike wont have a hard live as ive only been doing trials for fun ive got to bultacos witch ive just restord cheers bondy
  4. hi guys as some of you know i just got a gas gas 250 txt pro 210 dosnt need anything doing to it as its been well looked affter. im thinking the owner before me used putolin oils as the bike as all the stickers on not sure as i got it off a dealer i know the gear oil is red i can see through the littel window on the casing so have you guys any idea if putolin is red? ive been told 75W light is recamended. im not sure how mutch it mentions 500mm in the hand book but the book is for a 2008 modal the dealer said it was the same as the 210 so im just going off it. ive allso been told the petrol mix is 75mm to 5L of petrol? ive only had bultacos the last to years ive desided to try modan trials. must say they are great to ride alltho ive only took it up and down my street. anougther thing is how would i tell if theres a wieght on the flyweel? im only asking because ive read it on hear that some guys do it to carm the power down but would this be likley on my pro 250? what would the diffrance be? cheers bondy
  5. hi ive just got meself a gas gas 250 txt pro 210 model big diffrence to the bultaco i have. anyway can anybody tell me the best 2 strok oil to use? i know its 75mm/5 litters do i use part synthetic or fully synthetic? ive got some of that strawbery 2 strok oil thats part synthetic i used it in my bultaco once but it left a sticky layer on my carb slide. also what engin oil is the best for these bikes. and is it all one oil the bultaco as gear oil .and clutch oil cheers bondy
  6. Powder coating a gas tank is beyond the good manners I guess.
    The tank of a bike is well let's call it the face of a nice girl.
    Hopefully that statement and the one to come will not get me in any trouble).(
    Only very little make-up can improve the appearance but putty is the opposite.
    hi i understand what you mean im just gonner have it sprayed not powder coated cheers
  7. hi all the bottom nut on the yokes the one that holds the bearings in anybody know what size c spanner id need to tighten it up? i know you can use a big screwdriver but ive just had the yokes painted. and dont want to damage it or the nut?
  8. what ever it is the body shop will remove it, and sand back to the sound metal. Once there is a good base they will paint over that.. so no need to worry
    ok mate nice one thanks :thumbup:
  9. you've already asked this question a few days ago.....
    oh yes i did im sorr guys im gonner just have it sprayed normal the only thing i was worrid about was under the tank on the exhaust side the paint was bubbling just thought powder coating would had stoped this ill ask the body shop is there anougther way
  10. hi all on the last bult i bought had a alloy tank looks in good shape apart from a littal crack in the top it had been filled with fibreglass. would it be ok to have it powerder coated?
    hope this might help. i have only stripped the bike and do not know the history or anything about it. the engine and chassis numbers are the same, and its a 1975 model, 150.. 250 slimline. and thats all i know realy. its not a bad bike and i got it cheap to do up and to use for my first trials.
    The more i look at this now the more i think i'lll change it. Would't be over hard to make a T piece
    and a bar from the T piece that would bolt to the head and a bar to go from the head to the frame..
    Have to leave this one with me for a bit...
    hi again i dont think you have the right fram for the engin seems weirod theres somthing wrong somwere there is only to typs of headsteadys one for the 350 witch i have .and one for the 250 both look same but there not the to holes witch fasten to the head are diffrent closer together on the 250. and wider on the 350 the lenth is the same i think not 100% sure but if your saying the frame. and engin numbers match it must be the right frame. hope this is of help
    still doing bits and bobs as you can see. bars and rims are going to be black anodised
    for the time being. The wheel spindles have been treated and plated and the threads have been coated in
    dry film lube. the rest of it it just tarting up the paintwork.. still waiting for the
    swing arm to be sorted. then its that and the frame..
    hi ive just been looking at your headsteady can you tell me what the 2 bits of metal are thats been welded on?
  13. hi guys i have bultacos. and i am looking to buy a fantic i know a old mate of mine from years ago is selling his 364 can you guys tell me what size of engin they are and the year?
  14. Yep!
    In my personal experience with bash plates that are an integral part of the frame this is the way to do.
    If You ever do a complete rebuild and want to remount the engine to the frame (where the bash plate is a bearing part of the frame), make sure you have mounted the bash plate first, (just mounted, the bolts are mounted but not thigtened). Thgis makes the assambly much easier.
    One thing to note as your bike (model 199a) have the "weak/thingy" headsteady, please make sure that the headstady is mounted without any stress/force!
    The headstady has to fit on spot and the bolt to the frame has to be thigtened at last, (which may result in unthigtening the cylinder head too if the hole of the headstady will not match to the bolt hole for the frame!)
    Doing so you will avoid any overstress to the headstadyplate.
    hi thanks for your help i thought it would be that. ill let you know how i get on cheers bondy
  15. HI guys ive just got a new bash plate from todo trials in spain im having troubel putint it on the engin is in ive tryed it on a spare frame and it gose on just have to pull it abit with a driver throw the holes. i spoke to dave from bultaco uk he said they can be a buger to get on. and he allso said undo the bolts that hold the engin. i think this may be the problem theres abit of play before everythings tightend up to allow you to get the plate on i think this is my problem you agree?
  16. Hello Bondy, the Sherpa`s had lights from new. I know the 213 Alpina`s were a 6 volt system and you had to put a black blanket over you and the bike and start it up, turn the headlight on making sure you were in pitch blackness to see if it was on. They were horrible. I know because I used to ride one on the road. They did not use a battery. In the Bultaco forums there is a wiring diagram and a picture of everything you need somewhere. They were very basic though and needed a voltage regulator in line as well. Good luck. Bully Lover.
    hi bullylover i dont think ill bother sound like to much hard work. so ill pass just thought it would of been nice to have lights. thanks for your addvice bondy :madnoel:
