Hot Air gun that's all you Need no freezer if you already rebuilt a 198A then you will have no problem with the B the main bearings are just the same as the 198A I know many have there own method off doing the bearings.
I had a S/S plate made for mine that was the shape off the Air box hat the rear with 2 welded bolts that fitted perfectly also I had a flat plate on the front with a welded bolt. Makes Life easier. If its a New Air box you will Need to drill the holes for the side panels be careful they need to be correct or the side panels wont fir proper I have a old B box cut up with the original holes I use as a template works a treat. The under the top bracket holes I do last so I drill the side panel holes first then put the rubber bugs in and pop the side panels on then offer the box up in position so I know how fare back or forward the box has to go
Complete waste off time and money if you Ask me many have tried and failed the best tank to use for decals is alloy but don't see the point if your riding it unless you can get hold off 1 off the early plastic tanks with the printed decals they don't come off but do fade over time.
Not long completed my 199B it was a joy to work on runs well good Luck with the build. I still have spares I over ordered but will be used on. My next build.
Yes to the L/H if its the same has the trials bikes they some times get blocked just blow it out with a Air line or spoke a bit off wire throw make sure you don't drop the wire in there.
Won't fit been there tried it the B pipe is Longer and the A is shorter there for won't fit the angel off the middle section it different because off the Air box.
Chappo yes the seller is on EBay and you can run them out the box as I did think stu did put another pilot jet in but only as he said he was being abit fussy .
That's a good idea but it needs to be ridged also there should be a spacer in between the top bracket on The frame to add strength I had some alloy spacers made
Overheating problem?
in Bultaco
Posted · Edited by bondy
The carb needs setting sounds abit rough.
