frenchmike
44 -
Hi all, I know that the timing is between 2.2_- 2.3 mm BTDC, but can anyone tell me where the time marks are on the stator back plate please
Please can anyone tell me if there is a club in Co Durham, for my grandson to join.
Please can anyone tell me were my 14 year old Grandson can go to learn to trial near Darlington Co Durham.
I have a cope of 2009 EVO manual , and what I'm after, having just put in a new conrod kit, is the outside distance between the two cranks , which is 54.4 mm on mine before I started, and now it's 1 thou wider. I need to find out the tolerances for that, and for the end float . The 2009 Evo distance between cranks is 62mm on page 24. So this is the info i'm trying to find out
Thanks again worldtrialchamp , But it's a workshop manual I'm looking for not the owners manual.
They look the same but the spec is different , I need the earlier model from 2000 on, I have run out of ideas were to look now .
This might have been posted before , but has anyone found a PDF 2003 125 rev 3 workshop manual, please.
Thanks Lineaway for the INFO .
Paulc 76 Thanks for that.
Yes I have replaced the Connecting rod ,but there seems a lot of end float, dose anyone know what the free play should be
Hi, Dose anyone know what the Big end float should be for a 2003 125cc rev 3 please.
Thanks for you reply's , I a little confused as I have been told you can buy over sized piston, dose any one know about them , and has anyone fitted one ?
I have bad knocking at all revs but louder at low revs, sounds like the piston is going up and down sideways,its has already had one new piston in it's life. Any one got any other ideas , or have I answered my own. And has any one tried the new exchange recon barrel and piston from (<mention of this company is not permitted on Trials Central. Please delete this post>)
Hi please can any one tell me if it is normal to re'bore a 125 cylinder that's if it can be done, and where is the best place to buy a new piston and ring etc.
Tried putting a ladies ST on the offending part yesterday , worked well and no itching today , so whether it,s the lining material or just me , I,m not sure, I have washed the ling many time
