hilltopcycleatv
16 -
The coating on the front fork legs of my 04' 2.9 is peeling . I was wondering if anyone has ever had this problem and painted them ? Any pics would be great . Thanks,
I am thinking these will work . Does anyone know for sure ? http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=WLVXC5CMAPKEDQFIDYESM4WAVAPAQIV0?store=&skuId=14230&mmy=#fitment Thanks, Raz
Is there any aftermarket fork and dust seals that will work on my 04' 2.9 ? I have some seals for other bikes on the wall and would like to use them if they would work . Has anyone done any research on what ones will work ? Thanks, Raz
Is there any good free basic video editing software that can be downloaded online ? Thanks, Raz
What alot of people do not realize is that WD-40 is more of a solvent than it is a lubricant . I would honestly use anything over WD-40 . Just my .02, Raz BTW: I use Maxima Chain Wax or Amsoil MP HD
I am getting one that has only been used a couple of times , I can pick between a large and XL . They are not the carbon fiber ones .
Just wondering if these trials helmets are any good ? Thanks, Raz
Does the airbox come apart or do you just have to look down inside after you remove the shark fin ?
Shark fin - better explanation thanks Guess I had better oil it - just as I thought
I just bought a 04' 2.9 and I am going though everything to get familiar with it . I took off the gas tank and fender assy . I checked the antifreeze and it is ok . I then took out the airfilter that looks like a curved wedge . The air filter didn't have any oil on it , shouldn't you run airfilter oil on it ? Is this the only filter or is this some type of pre filter ? Thanks, Raz
I just got a 04' 2.9 and the front forks look like grey paint is peeling from the lowers . Were these painted from the factory or is it some kind of anodizing ? How do I clean these up and make them look better cosmetically ? Thanks, Raz
Do you happen to know the seal #'s ? Also, Are you going to the Hangover on the 1st ?
Does anyone know the #'s off the bearings and seals for the rear wheel on a 2004 Sherco 2.9 ? Heck , I guess i might as well know the front also if anyone has it . Thanks, Raz
