fanticsjj
13 -
I have ordered the honda cg front mount which will be attached to the down pipe at the front that will need extending and then will remove the 2 bits that go underneath the original engine then have some brackets made up to attach the rear mounts also going to add a alloy bash plate to brace under the engine ! That's the plan anyway
Original mountings
Been to collect engine ! Seems big did you remove the bottom part of the frame Hendrik
Hi Glenn I bought the frame off someone who bought a house and it was in the cellar thinking I would pick up a engine to fit and get it going but searching about realised its not a easy job ! Honda engine seems the way forward although all my bikes have been 2 strokes so know nothing about 4 strokes . I'm going to look at a engine on Sunday and I will post a picture as to size mountings etc once ive made any alterations then will get the frame powder coated ! Do u recommend any other frame mods before getting it coated ?
Found a xr125 engine is that the same as the tl engine ?
Thanks for the advice would prefer genuine honda engine but will see what I can get ! Will keep updating
thanks for the reply i understand about the mono engine ! would a swing arm off another fantic twinshock fit ? ( one with a fantic engine ) if not which honda engine would you use ?
looking for any info on engine type ? i know originally it had a minarelli engine ! can i fit a 80cc air cooled mono engine ( with mounting mods ) or any other suggestions to get this back to where it should be thanks in advance steve
HI DID YOU GO ANY FURTHER WITH THE PROJECT ? I HAVE JUST GO A FM330 FRAME AND WANT TO BUILD A TWINSHOCK 80 0R 125 IF POSSIBLE THE ORIGINAL MINARELLI ENGINES ARE HARD TO FIND IN THIS COUNTRY AND INFORMATION WOULD BE HELPFUL CHEERS STEVE
HI I HAVE JUST PURCHASED A FM330 FRAME WITH WHEELS AND LOOKING FOR A ENGINE AND OTHER BITS AS MUCH INFO ON THE ENGINE AS POSS ! DID YOU END UP GETTING THE BIKE ? THANKS STEVE
HI JUST WANTING AS MUCH INFORMATION ON THE FM 330 OR 43O AS POSSIBLE ! I HAVE PURCHASED A 330 FRAME AND WHEELS AND TANK AND WOULD LIKE TO BUILD A BIKE 80CC IF POSS IVE BEEN TOLD THE FRAME IS THE SAME SO ON THE LOOK OUT FOR ENGINE SEAT ETC ANY INFO WOULD BE GREAT CHEERS STEVE
had one of these a couple of years ago some parts still avilable from gasgas uk it was called a gas gas aire i think
