big wheeler
28 -
AIM
gollummaltby@aol.com
Thanks for the answers to my other questions i now have another couple you can perhaps help me with Should i bathe the air filter in oil before fitting or should it be fit dry ? How often should i change the engine oil Thanks once again yours mark m
My son has just bought a 2002 txt 280 pro and we have a couple of questions we would like to ask How much 2 stroke oil should we put in 5 litres of fuel ? Are sticker kits available and if so how much ? Who are the main dealers for gas gas in west yorkshire ? OOPS sorry thats three questions THANKS MARK
Hi give raz sport in brighouse a try they have quite a reasonable selection of bikes and only about 20 mins down the road from you
Hi im repairing one of the local lads rev3s can anyone please tell me the torque settings for the barrel to crankcase nuts and the cylinder head bolts cheers
how do you set the timing on a tr34 is it possible to do it static or is at a shop job
After rebuilding my tr34 engine im having problems getting it to run properly it will start with the choke out and warm up when i push the choke in it slows to a idle the problem starts once i try to rev it i have followed the instructions for setting up that i obtained from off-road .coms ride -net web page for the mikuni carb but i dont really know which screws are which i have a large thumb screw at the base of the carb which i assume is the idle air screw or pilot air screw i dont seem to have a throttle stop screw or cant see one on the side of the carb. When i open the throttle it seems to choke the engine regardless of where the thumb screw is set believe me when i say i have tried it from fully closed to fully open in 1/4 of a turn increments to no avail apart from my left foot being black and blue from trying nearly all bl---y day any help will be greatly appreciated as im at my wits end and sick of hearing it go buuuurr and die out.
I dont know how they work but iff anyone can explain it would be greatly apreciated The reed valves on my tr34 are in 2 parts per side a large piece that covers the whole of the wedge they are mounted to and a smaller piece that covers two smaller slots on the large piece should there be a small gap between the large piece and the small piece this is only about .5mm i have tried turning them over but the gap remains the same so what i really need to know is should there be a gap and iff not will it affect the performance of the bike or am i worrying about nothing
Hi im looking for the right hand side panel for my TR34 to finish off rebuild so iff you can help pleeeeeeeeeeease get in touch many thanks mark
Hi i will be getting my engine bits back next week new piston re nicosiled barrel etc what is the best way to run it in and what petrol to oil mix should i use.Can anyone also explain how to set up the mikuni carb fitted to my bike[tr34] as i suppose this is critical so i dont run it too lean but i dont know what all the screws are for yours mark
Can anyone tell me why the mikuni carb on my tr34 has a little round plastic window in the side of the slider body cheers mark
Hi i watched your bike on ebay with great intrest as im just in the middle of rebuilding mine iff its as good as the listing suggested i think you have done well for the money.I have stripped mine down to the last nut and bolt and beginning to re-build from what i have seen so far they are very well put together only problem there isnt much info available for them so when you get stuck you have to start picking everyones brains but so far no real problems yours mark
Thanks for the info i will be using langcourts for sure and for anyone who is intrested the thread on a tr34 flywheel is 26mm x 1.5 pitch and the 26mm is a right hand thread unlike on some machines which are coddy handed cheers mark
cheers i was thinking of using a firm called dps who advertise in trials and mx news but i suppose they will just sub it out anyway so decided to send to langcourts
cheers will have a trip to lampkins as i only live about 10 miles away
Good idea the modelling clay but managed to find some pitch gauges at work that will fit inside,will have to measure tomorrow and yes it was a runner before stripping just down on power due to bore wear .i will try to post some pics as rebuild continues yours mark
