hubba
    5
  1. hubba
    oil pressure
    another question for you jon,i have just replaced a cracked side casing,also a quardrant gear and a idle gear which was badly damaged and was told this was the problem as to why the side casing broke,just out on bike and after an hour the new side casing has just cracked the same way as the last one,the kick shaft has a little play in it but other shafts on other gaser has more slop than mine,the shaft was taken out but is nice and straight with no signs of wear on it at all,the casing seems to be breaking with the action on the kick start,am goin to send the new cracked casing back to gas gas for inspection hopefully to get another casing for free,would you have any knowledge on this as the shop were it was fixed seems to be as confused as i am,i have just left it back down there to be fixed again for the third time.any advise would be gratefully recieved,NEIL (hubba)
  2. hubba
    oil pressure
    Many thanks jon ,ordered 1,this has been doin my head in for months,thanks again
  3. hubba
    oil pressure
    Hi jon,as not to hopefully sound stupid what exactly is the hub capscrew,would it be the screw that holds on the clutch basket/hub the small allen key head 4mm?
  4. hubba
    oil pressure
    hi there peeps,just on at this stuff,can any of you guys help me ,i have a 06 300cc gaser and have an on going problem that the gearbox oil pumps oil out the overflow pipe,i have had the pressure seals done which slowed it down a bit but has not cured it ,the guy who was paid to sort it has had it stripped right down twice now and dosn't seem to have a clue what the problem is ,he seems to think it's ok for your overflow pipe to be constantly full of oil and air pockets,even when theres only 200 ml in the thing,am starting to run out of ideas,HHHHHHHHHEEEEEEEELLLLLLLLPPPPPPPPPPP
