Service manual?
Hi , could i have a manual for a 2018 combat 300? thanks jeff@stringfellows.co.nz j
Fuel Mixture Screw 06 300 Pro.
The bike is new to me and I have noticed that it felt a little like it was loading up (rich? ) when past half to full throttle. It has a 118 main, 40 pilot , d34 needle with the clip on the second clip from the bottom. The starter jet is a 100. and there is 200 stamped on the needle / seat base. The mixture screw was 2 1/4 turns out. The float arms were a bit higher than parrallel. I am running Motul 800 2t at 25mls per liter ( About 66:1 , having run enduro bikes for the last 10 years I am finding it hard to get to 80:1 just yet.) Yesterday I adjusted the float arms to be parallel as per the manual. This didnt seem to fix the problem. I was then playing with the mixture screw , I turned it out 3 1/2 as per JSE's instructions but that didnt help either. As a stab in the dark I turned it right in, the idle got faster but it didnt fall off the idle like I had gone past the sweet spot. I then backed the screw out to 1 1/2 turns and it seems a lot better. There is now a smooth pull right through the revs . I quess the question is , what does this mean.? is the carb jetted to lean? I am assuming that the mixture screw is richening the mixture the further you turn it in? Can anyone point me in the right direction. I dont want to go to lean and burn it up. Thanks for your help.
Air Filter
Hello Steve, to answer two questions at once. Kerosine is an abrasive that needs to be well flushed when using on metal parts. Learned this from a small engine mechanic. (lawn mowers weed eaters etc not a midget.) I have always used kerosine to wash out dirty air filters then qive it a flick across the lawn. Then use a small amount of laundry powder in some warm water , wash and rinse. Then repeat the wash and rinse step. then rinse again. If you are a bit fussy with filter maintenance you can use a white plastic container to do this. you can then see when the rinse water runs clean and the container has no grit left in it. This works for ktm300 filters and they suck a lot more volume than the gasser does. This works with most filter oils as such, not sure about the no toil type products. Petrol should only be used as a last resort due to the flamabilty and the fact it eats the glue that holds the fliters together. Regards
2006 Pro Magneto Cover Letting Water In.
Thanks Jon will get one sorted.
Thanks guys. These sound like a good solution to the problem. Jon , is that breather just a generic type avaliable at any auto part store or something specific. ? Regards
Hello all. Went out for my first real ride on a new to me 06 300pro. The ride was in a dry dusty paddock with a small creek splash to get across. 4 inches deep at the most. After I washed the bike I took the magneto cover off to have a look in there. While i was getting the cover off a small puddle was forming on the floor from inside the cover. The water is clean and I can only guess that its from the wash down after the ride. I had the cover off last week and was a bit damp but not this wet. the bike was washed with a hand hose and brush not a water blaster. Any ideas where to start waterproffing it. The flywheel is showing signs of being damp in the past. ( rusty etc) It looks like the water may be going straight down through the wires coming out of the case. I need to get a flywheel holder and puller and I will pull it off and have a good look behind it to see how wet it has been. Thanks for your time.
2006 Pro Front Wheel Spacer And Bearings.
Thanks Guys. Thats the numbers I was after.
Hello , Can any one tell me if an '06 300 Pro has a spacer on the axle between the hub and the disc side fork leg? Secondly can anyone confirm the front wheel bearings are 6905Rs?. Thanks for your time.
06 300 Pro Sunny Rainy Map Wires
Thanks guys . Thats what I was after.
Hi all, first of all thank you to the people that gave advise on the 01 321 verses 06 300 decate. I bit the bullet and bought the 06 300. The wife will have to wait for the new kitchen a bit longer. The only switch left on the 'bars is the kill switch. Can any one tell me where to look for the wires that would have been connected to the rain/sun switch. And what colour they should be. Also I have seen some other posts that suggest that if apart that the setting is rainy can some one confirm. Thanks for your time.
01 321 Or 06 300
I have been looking for a tidy '01 321 for the last year to buy. I have got one that I need to get some more details on but I now have the option of an '06 300 that hasnt done a lot of work for about 25% more. I am undecided as I have heard that the 300s are a bit harder on the gearboxes and kickstart gears etc. But they have latter technology etc. Anyone have strong views either way? Anyone gone from a 321 to a 300pro. ? Thanks for your time.
Tl125 Alternative Carburators
Scooter I am in the North Island of New Zealand. Although it is summer here we only have moderate temperatures. Because my bike is a project made form three wrecks I have never had a heat sheild and am never quite sure what is standard on these. What material did you make the heat sheild out of. I must apologise for getting this thread side tracked. The internet sure makes the world a smaller place. regards Jeff
Hello Scooter, I recieved an email from Re-MX to say that some one had dropped by with an "S" carb. I quess that was you. He said that the xr 75 carb would work and that he has jets to fit. He also said that the "S" carb had a 105 main jet in it. is this the size that you are running.? what pilot jet do you run in a 125s motor. That is pretty neat that you live nearby and can call in and check over the parts. Living at the bottom of the globe I need to trust what the seller tells me and take a gamble on any purchases. Thanks
Scooter, regards the heat sheild between the carb and manifold. Have you run a bike without it? I have never had one on the bike that i have. Can you give me some dimensions for the sheild and I will make one and see if that helps with my issues.
Scooter. Do you know if the "S" carb is the same as anything else of that era? or is it TL specific. Are the XR 100 carbs 22mm and higher bodied like the SL 125s. Thanks
rmxboy
