creaser
21 -
Hi I have a 2010 300 raga which I recently stripped the engine to replace the main bearings and found a cracked casing. I have bought some standard casings not magnesium ones. When I came to put it all back together I found that all the gears are there and fine when going up the box but when I come back down the box it seems to be awkward going into third. The gearbox seems to go tight. Also has anyone had trouble with main bearings being the wrong size. I bought some non genuine ones when I fitted them you couldn't turn the crank so I took them out got a new set from gas gas which were the same. When I contacted gas gas I was told the bearings had been manufactured the wrong size 23 mm deep instead of 22.5mm
Hi. I have a 2010 txt 300 pro raga which I am about to replace the main bearings. As the engine is apart I thought it may be a good idea to change the rings. My question is has my engine got a s3 piston fitted as standard. Also do you think it is a good idea to get the crank balanced while it is out. Thanks
Hi has anyone got a wiring diagram for a 2009/10 12.5 oset please Thanks
hi everyone! i have a 2004 sherco 125 and have picked up a 200cc barrel and piston.i am going to fit it very soon i was just wondering if anyone out there knows if i will have to rejet the carb and if so does anyone know what a 200 would have as standard jets thanks
hi can anyone tell me where i can get some fork tubes recoated my friend has a 2006 sherco 290 with black chromed fork tubes and the left one is damaged
thanks i must have the newer coil pack on my bike as there is more then three wires thanks again
hi ! i,ve just got my step son a 2004 sherco 125 and i want to wire in a kill switch can anyone tell me which wire i connect to. thanks
hi! my step son has a 2004 gas gas txt 80 rookie. I am trying to get a little more bottom end power out of it. the bike runs really well and pulls like a train at full revs. This ok but steep hills have to be attacked in first gear flat out.. I have read the other posts about the carb mods. The carb slide is all ready modified. I was thinking about changing the front sprocket from a 12 tooth to a 11 tooth has anyone given this a try before and was it any better? thanks!!
hi i hope someone out there can help me i have a 2000 beta rev 3 with upside down forks and i'm replacing the fork seals and i'm trying to find out how much fork oil i need to put in each fork leg.
hi i'm hoping someone can help me. one of my friends has a 1994 gas gas 250 and on sunday we were out on the bikes when his bike starting misfiring and then cutting out. we tried the spark plug it ran for a short while then cut out again.this time it would not start.i've checked for a spark it does have a spark but it is very weak. does anyone have information on how to check the stator. thanks creaser
hi ! i had a similar problem with a scorpa i used to have. in the end it turn out to be the stator . i had the stator rewound and it started first or second kick every time.
where in north wales are you?
hi could anyone out there tell me how i can tell the age of a beta 250 techno as a friend has just got one but has no real idea what year it is . i think it could be a 95/96 but not sure. thanks creaser
