moulder75
52 -
Sorry, can you explain what you mean by 6mm preload? Is that 6mm compression shorter (using the c spanner) from the total (uncompressed) length? What colour was the spring? Thanks for the info Im off into the shed to go tinker.... Tony
Billy - Now that the old chap is grafting them back together with aluminium and pop rivets I can splash out lol. Anyone got an Ohlins hints and tips?
Have been riding with my new ohlins rear shock for a few months but thought I should set it up in accordance with the manual. I weight 10.5 stone (approx) and seem to be winding the spring until almost to its tighest point to match the measurments quoted in the manual (wheel off ground length - length when stoof on bike). I have a yellow spring which I thought was designed for people slighly heavier than me hence I would imagine that the spring length would have to be at almost its longest to suit my weight. If anyone has an Ohlins fitted, what is the length of your spring? And did you manage to set it up in accordance with the manual? Cheers Tony PS - The shock feels ok no matter what the spring length is, as to be honest I do not know what is good or bad etc.
I have been running my Hebo tank for a year and it worked fine in Scotland last year. Just poke the Beta breather pipe (Attached to fuel cap approx 3mm dia (OD)) into the end of inlet pipe supplied on the aux tank which is attached to the pipe which goes to the bottom of the aux tank (Like a drink straw). You have to thread the hebo pipe (Black) between the bars and headstock such that it is close to the Beta fuel cap and breather pipe and allows you to rotate the bars from lock to lock with nothing catching etc. This syphens fine on my bike, but I have heard a few stories of this not being 100% effective. This method means that the aux tank empties first and when refueling the bike (Main & Aux) you just pull the fuel cap breather pipe out of the end of the aux inlet pipe. I had this on my 09 Evo and it also works fine on my 2010. I hope this makes sense and helps Cheers Tony
Still not had my letter but I should be a memebr of the official CSMA team with Billy C so should be good news when the snow clears and the post works again round my way.
I have not registered for this championship at the start of the year but was thinking of having a go at the round in Kent. The ACU website does not appear to be very helpful, hence I was wondering if anybody knew of the Kent club website address? Is it possible to ride a round without entering the whole series? Do you really need a minder for expert B? I know that I am going to struggle getting round but want to give it a go as otherwise Il never know if I could ever get round. If anybody wants to see some good crashes they should watch me ride the sections lol. Tony
Quote Depends when the pedals have been made I guess. I think the top lads had a bit of an issue so the pedal now has a little extra bit on each side. Mine was fine before. Pedal has a little bit extra of what? Width? Length? I find it difficult to cover the rear brake when attempting to hop on the back wheel. I still have not mastered it yet lol.
What have the problems been with the rear brake caliper and pedal? I have an 09 250 and was wondering what to look out for if a problem starts on mine? Im riding the manx 2 day hence I dont want the bike to jack in after the
Anyone know if and when the 09 Jitsie riding gear is going to be on sale in the shops? It was mentioned on the TC main site before Christmas but I have not seen or heard anything since? Cheers Tony
I had an 08 250 rev 3 which the gearbox broke in a similar fashion to what desertrat28 experienced. Luckily it was still under guarantee at BVM as it was only 3 months old. This happeneded while the bike was on tickover with no obvious abuse in the past to cause the fault. Beta UK covered all the costs which was very helpful as the break occured 3 weeks before Scotland. After a lot of stress and worry the bike was fixed with a few days to go before Scotland. The bike was then fine unitl I sold it before Christmas. I think my first gear shaft snapped in half taking out a few other gears. Either way credit must go to BVM and JLI for there excellent service and support. Tony
I think I read that there were 365 entries which If my calcualtions are correct means that there will be 95 unfortunate people. Am I right in thinking that there were well over 400 entries last year? Either way good luck to all those that have entered, il be crossing my finger and toes this weekend. Cheers Tony
The suspense is killing me!!!!!!!!!!!!!
Theres a very small circlip which stops the bearing being pushed out on both sides. You can use a good vice and some cleverly placed half inch sockets to push the worn bearing out and push and new one in. It took me ages to notice the tiny clip on each side, which is not very obvious. Hope that helps Tony
The website www.manx2day.com stated a few weeks ago that the trial was planned for the weekend of the 23rd of August next year. I am trying to book ferry's and accomodation and I have since seen dates for the weekend of the 29th on the acu fixture list (Posted on this website) and also now on the manx2day website. Can anybody confirm when this trial is going to be held or have any contact details for the organising club secretary? I have tried to email them with no success. Cheers Tony
Yeah I have an enduro front tube. Il probably go for for 7 and 5 and I can always let a little out at the first petrol stop if I think its too hard. Cheers Tony
