nubee1974
33 -
There are a couple of things you could try. Try putting some grinding paste into the knackered allen hole and then using the original correct sized allen key to undo the bolt (this rarely works) As stated, cut a flat edge through the bolt head and use a flat edge or impact driver to try and shift it a bit. remove all the other bolts, drill the head off the knackered one (using small to larger drill bits in the centre of the bolt), remove the cover, use some mole grips to on the now showing bolt shaft. Good luck
Hi there. I'm wanting to put some fatbars onto my 4rt. I'm wondering how i manage to fit them in place of the standard ones. Also, where can i get the parts needed. I'm also looking at putting a larger clutch master cylinder on. Again, i'm wondering where i can get one from, preferably second hand. Thanks in advance. Chris
Hi. I have just acquired a bog standard fully original 2005 4RT. It has the most awful breather pipe coming from the tank with a what looks like a valve and then the breather pipe goes back below the tank. I haven't has time to figure out what it's about to be honest but am wondering whether or not it is needed or whether i can cut it back and plonk a little one way valve on it? Are there any other alternatives to what i can do with it to make it look a bit tidier? Cheers Chris
Fact
That is what is confusing the crap out of me. Advised me not to use ATF as it will eventually destroy the clutch
Hi. My local dealer has told me just to put Putoline nano tech 10-40w in both the transmission and the engine. Does the seem okay to do? Cheers Chris
What are your thoughts on the engine oil, fully synth, part synth? Will decent car 10-40w be fine? Cheers Chris
Hi there. I have acquired a 2005 rt that has done very little work and hasn't been used for some time. I've bought a service kit from pitcocks but I'm at a loss as to which oils I can/ahould use. Which oils do you use for the transmission and engine? Thanks for your help! There maybe more daft questions after this one!! Cheers Chris
Or note this price http://www.splatshop.co.uk/jitsie-lanyard-magnetic-kill-switch-4967.html
Cheers for the shop names Chris
Hi. My local trials shop doesn't sell what I need (some alpine star boots). I live in Middlesbrough and am off to Leeds and Newcastle shortly. Does anybody know of any decent trials bike shops in them areas? Cheers chris
Back is off, Down is on, Forward is reserve. I always leave whatever fuel is left in the tank without any issues.
Thanks for your replies Could this have anything to do with me changing over from regular unleaded petrol to super plus unleaded? Should I stop and go back to regular? Cheers chris
