kevinbouy1888
14 -
forgot to say its a 06 rev 3 250 thanks for the comment
hi i am wondering how to do the crank seals am thinkin you need to remove cluch face,basket and the primery gears behind it and then you should see the left seal am aye on the right track any help would be great
hiya dudes i have some problems with my o6 rev 3 number 1 going through plugs like know ones business and they are all carbond up number 2 smoking like a bonfire (white) smoke on all cold starts it is not useing any coolant done gear box oil only 100 ml came out so changed it to 500ml and is ruing like a bag of spanners mabee a seal leting oil into cylnder or the rings leting oil past dnot have a clue any help would be brill thanks!!
hiya is 500cc the same as 500ml of gear oil thanks.
thanks for replay it isint eating the coolant when the bike is switched off not runing as if you where puting it away
ok dudes there is a weird whistling from the top end when the bike is off am thinking head gasget but not sure becouse it was only done a few months ago?
cheers any idea the cost ????
hi people for some reason it seems the piston in the brake master cylinder has fallin out and got lost so the brake dont work a see there is kits for every other bike and year bar 2006 upwards any help would be good or were a could get a secound hand one thanks
hiya every one is the oil meuser for beta 2006 250 550 ml in the box??
there is a weird winein noise coming from the bike at top speed or near it it sounds like if the coolant is low but it isent n when on cold start the bike is dead smokie any help?
how to remove the bottem yoke ok 2006 beta rev 3
kevinbouy1888 replied to kevinbouy1888's topic in Beta
the threded ring the one ontop off the barring a tried taping this aswell but no luck -
hiya could any one have an idea on how to remove the BOTTOM yoke on the 2006 beta aye have removed top bolt the yoke and the other bolt then the cover n washer but there is a what looks lika a spacer on top off the tapperd barring there is no other bolt at bottem off yoke and this what a amagen washer is stuck on SOILD HELPPPPPP PLZ
