gasgasian
28 -
hey there, We got it sorted it was the boyesen reeds! Put the standard reeds in and its fine! works great! Thanks for the help, Rob
it has been doing this for some time now. It works ok for a while when the plug is changed. What is this an indication of? plug break down? Thanks Rob
any more help please? Its really important! Thankyou Rob
I have an 07 Sherco with a blown shock seal, has anyone got a replacement shock hanging around in their garage? could do with it being cheap!! with correct bushes etc. If you have anything call 0771 405 8986 Ian
Copemec, thanks for reply, i could try shorter lever, matbe could put some washers under clutch springs to relax spring pressure slightly? Whats this about timing alteration? have you any details, retarding by how much? Will it affect power though....I need loads..:-) Had Boysen reeds in all my Gassers, mega move!! Regards, Ian.
Thanks for reply but with boths oils it is still not as i prefer. In fact it made no noticable difference.. Ian
Can anyone shed any light on setting up my Sherco clutch?, its a 290 07 machine, having rode Gas Gas bikes for a number of years, (to many!) I have always had a light and smooth clutch action which had a definite release point; I put ATF Dextron 3 in gearbox and have also put same oil in Sherco box. The Sherco clutch seems fairly heavy even with AJP long levers fitted for leverage and extra control. My lad had same light switch clutch on his Beta but we cured that after sandblasting clutch steel plates, it
where did you get the reeds from?
can anyone tell me what reeds are available for betas and will I have to change the jetting? thanks
are there any protectors available for betas? preferably carbon fibre
water keeps flooding into my beta' flywheel cover and I just wondered if there was anthing I can do. I have sealed it up with silocone!
I was wondering if anyone had any idea how to stop a very snatchy clutch problem on my beta '02?
The thermo is jammed, put a inline old style one in, had same prob with both my 05 Raga's.Fan does not kick in straight away, but when started will not stop!! Regards, Ian. ps.Better heat range as well.
I use my bike 2-3 times a week then ride at weekend, so its not mollycoddled,have plenty of crashes, what its for i suppose! its difficult to be subjective on build quality because some bike are used once a month or less. i realise that some bikes are a bit better built, probably Beta are a bit better, and also Monts, but for ease of riding it takes a lot to better a Gasser. My wife was even threatening divorce if i did'nt change to a Beta after all the aggro from the Gas Gas's I've had, but i still ride one. Not sure if thats loyalty or stupidity!!
i think if you look at a gasser frame its joined about where that bike broke, the frame is welded there, then ground , polished and chromed. The Gasser is a fantastic bike but as a long time Gas rider very iffy in build quality. But i keep buying them.. Lets hope that 50 mil euro's get the standard up a bit!!
