jamessut
20 -
cheers for the help going to replace the bolt and try back bleeding it, do i just attach the syringe to the caliper nipple, also where do i get a large syringe from?
i will pick one up this week and give it a try, take it you have come across the same problem? No i haven't back back bled it what difference does this make to bleeding it through the reservoir?
i have cleaned the pots and they move freely, the brake works fine but then just loses all pressure but the reservoir is still full, that's why i'm not sure what to do next. If it did have a leak from the banjo bolt wouldn't the fluid drop in the reservoir? i have the cylinder with light switch incorporated?
I'm have having problems with my gas gas txt 2004 rear brake, i have bleeded the system many times and the brake works fine for the first ten minutes then all the pressure in the lever disappears and the brake doesn't operate at all, there is still all the brake fluid in the bottle so i'm guessing nothing is leaking or this would be empty, any ideas? thanks
Yes the gasser is a early pro, really nice bike but just wanting something newer. Might just be better saving some more and going for a 2010 gas gas 250 as i like the gas gas bikes, rode a 2009 gas gas and it felt more compact than mine and alot lighter on the front end. thanks for advice
just been looking at a sherco 250 2008 model and just wanting to know if this would be a better bike to have than the 2004 gas gas i currently have. thanks
Hi everyone, Just after some help, i currently have a gas gas txt 250 2004 model and i am looking to upgrade to some thing a little newer. Is there much difference in weight dimensions of newer bikes, looking round 2009 year. Also are the newer bikes easier to control? Any help would be great thanks Thanks james
Thanks for the replies, just checked photos out.
Just wondering if anyone knows who the photographer was at the above trials on saturday, saw him about on the kawasaki just wanting to see some of the pics. Thanks
Thanks for the replies, i entered my first trials on saturday at home farm, bradford. I entered the novice class and found it ok bit more practice needed now i know what to expect.
Entering first trials and wondering what class to enter any advice would be good! Cheers
Thanks for all the advice, going to measure the plates whilst I have everything drained.
Thanks for the replies, what would happen if someone before me used mineral oil instead of dot 4 reason I am changing it is clutch seems to be heavy compared to others and my forearms are like popeyes after a short time
Just wanting some advice about which is the best oil to use in my Gas Gas txt pro 2004, clutch fluid and gearbox oil as i am changing next week any advice would be appreciated. Thanks
thanks again for the advice, just been and picked up a gas gas txt 250 2004 from adrian at TOR, nice clean bike just waiting for tomorrow to go riding.
