I have an 010 and the bike came with a shorty lever, swapped output for the long lever and the geometry is different and although it has no effect on clutch drag it improves clutch feel substantially
Hi, I purchase a 2013 evo250 fact, to my surprise the carburetor air screw does not have the flex remote line that my evo 2009 did have. Now with out this flex line it is almost impossible to adjust the air screw without removing the muffler. Were can I purchase the air screw flex line ? I look at part number and they are all the same from 2009 to 2013.
steven
You could also make your own with a short piece of old speedo cable and silver solder
Haha. As for the shorts, im a game ranger and try to practice for a hour every day in my lunch break. Im saving my pretty beta gear for events.
Seriously, can my drums be too slippery making it dificult for me to get this technique right? There are some rocks for me to try it on but ill have to get a armed buddy to watch my back if I ride in the bush here, lots of eles and lion around at the moment.
Supose I could make a rifle scabbard to fit on my beta and wear my 44mag, but it might be a bit restricting and heavy
LOL, we get the odd black bear, lots of deer and a moose or two
Minders don't have to carry a large caliber rifle to guard you from the wildlife, that's kind of interesting for sure but I'm glad I don't have to watch for Elephants in a section
Sag is not applicable as its to allow the wheel to drop into a hole at speed and not affect the chassis, we don't have this speed thing
Springs are suited max of 180lb rider stock and probably need to be changed for heavier guys and its all feel
Ryan Young teaches that you set up the front and rear independently
Having said that, it's tough to get setup advice as its completely subjective, some like lively and some don't, you want the back to have some bounce, not completely damped like MX
The old chassis is not a easy to ride as an Evo is so its not a current model and wont feel like it
But if its clean and well taken care of and the price is right then get it, if it turns out to not suit your riding style then punt it and find what works better for you
It may be your first trials bike but like all of us, it won't be your last
Well they are m 7 special bolts (shouldered) and appear the same on all model sizes. Guess I'm going to blame my torque wench ,but its odd as its a decent one.
Borrow another torque wrench
Torque a nut or bolt
Felt pen the socket and the work
Loosen
Use the other torque wrench and torque to same value and see if the felt pen marks line up
We use this to check cylinder head torque etc, works well
If the marks don't line up then the 2 wrenches are different
"I myself keep thinking I will find an oil that lets my bike shift
For the love of god why can't a 2010 model motorcycle find neutral just once with the engine running!!"
Jeff, A wee tip, on trials bike you find neutral with your heel.
You change gears with your foot and shift into neutral with your heel.
Strange I know but that is a technique that I find works for me and some other people.
Thanks, Ya I will give that a try, I also need to measure the shim in the clutch, it's a small amount of drag that causes it
It shifts by rev matching with no clutch rather well, but I am very hesitant to up shift in a section
If I load the shifter and hit the kill switch it will shift as soon as the engine stops
Clutch action after removing the glue is very good, some oils are better than others, the oil I had in there last tended to foam, a little comes out the breather, so I'm giving Bel ray a shot
Then some Motorex then the heck with it, TMDT at that point
"I have spent many years explaining how technical stuff works"
As most of us have on this forum. In fact there are many guys on here who do it rather well and have done so for many, many years!
Some of us even do it for a living!
Billy, never tried to pick a fight
If I said pistons spin round and round one would expect another to explain that they go up and down
Yes some of us do it for a living, motorcycle mechanical diagnosis and technical training is what I have done for 28 of the 33 years I have worked in the industry
FFS had valve ripped off last time was out fitted new tube but couldn't get it to seat so put strap round it and went like crazy with the pump so much so that the bead came off the rim and boom now have no tube. what tube would people recommend for rear std or hd or uhd
I think you have a problem there
Tires are not supposed to come off the bead when filling with air, might explain why it spun on the rim and tore your valve stem off
Sticky Clutch Rev 3, Beyond The Clutch Fix Sticky
in Beta
One good point there is the lever
