Hey, there are plastic darts that Yamaha uses on ATV fenders and snowmobile windshields are mounted with plastic 5mm screws, I could come up with some part numbers if you are interested
Well....been through a lot of snowmobile setup for those kind of altitudes, it is all about barometric pressure on the surface of the fuel and loss of signal strength at lower engine speeds
Main drops about 3 sizes
Pilot may or may not change, reduced atmo pressure means less fuel flows through the pilot so it corrects itself to a certain extent, it may drop a size or it may even run lean and need to be up sized
Needle will probably drop one clip
But you need to be careful at low alt's after you make adjustments, particularly at partial throttle you can squeak it on the needle
Opening the air box up helps a lot at altitude but you can't really do that on a Rev
I will try and look at mine after work tonight, you probably only need one wire to the fan and then to the sender but there would need to be a ground on the sender to complete the circle
Replace stator and rectifier?, very very unlikely that both failed at the same time, I don't get it
Did your headlight work?
As a general rule, a tech who replaces everything without a very clear explanation is questionable
Example: "the stator made no power so i replaced it and guess what, turns out the rectifier was frapped too"
is it possible he is incapable of diagnosing and just throws parts on.?
Still no fan, = neither the stator nor the rectifier were the cause, maybe you have a wiring problem and you got to buy the entire electrical system instead, ouch
Certainly you deserve a very clear explanation, the tech should have a "Wow your bike was a nightmare" kind of story
Did he give you your old parts back? He should have, test them and see what's up
It's the learning that really attracted me to trials.
Knees hugging the bike and steering to ballance are definitely habits I need to shake off, I caught myself kneeling on the tank at one point.
I'm struggling to cover the back brake when I think it might be needed, I think that in part was keeping my feet tight to the motor.
Cheers
Yup I'm right there with you, riding the rear brake is a street bike habit as it settles the bike down, I'm constantly working on getting away from the rear brake, my coach gives me a hard time all too often
A guy at a trial told me to say "ballerina ballerina ballerina" in a section to remind me to keep my feet and knees wide LOL
Rear Mudguards 2012
in Beta
Just a thought
