leckers78
12 -
Got a 1993 GG just bought a new piston/rings and had the barrell re-chromed (re-sleeved) new little bearing and a gasket set How long should it be run in for etc
Hi cheers for the reply the petcock valve is ok i have removed the fuel pipe of it and when i turn it on there is plenty of fuel coming out how would i be able to tell if the float valve is good or not?
I bought a 93 GG and its a complete biatch to start......... I have cleaned out the carb which is now spotless....... I have replaced the fuel in the tank........ New plug and cap (Good Spark) and adjusted the plug gap correctly...... it doesnt matter how many times i try and kick it of the dam off it will just not fire up UNLESS...... i drain the carb after using it by turning fuel off and letting it run out.... then the next time i come to start it, it will go after about 5/6 kicks..... Is this normal or should it go now matter weather i leave fuel in carb or not......?? Any ideas of how to get round this so it just starts like any other bike????
Any body know how much it cost to spectate today please
Some quality pics there lads/Lasses keep em coming
1993 GG 250cc the reason i ask about coolant is that the red stuff is for aluminium engines i think
Another couple of question 1. What type of coolant can i use in the water either the blue stuff or the red stuff (Both car coolants but shouldn't matter should it) and what mix 50/50?? 2. I have read that i should use ATF for the box, but can i use any as my father has loads of it at work which is used in Caterpillar excavators so will be top stuff?? 3. And also on the box is it just like a level bung you take out the side near the kick start and fill up till it runs out the hole?? Cheers wayne
I rang GG Buxton today about mixtures and they said 75ml-5Litres
Was looking through the forum last night and came acros a thread about how you can tell what age etc the bike is by looking at the frame number as the number tells you model and age etc BUT cant find it now can some one put the link on this thread so i can look at it again PLEASE
Just joined up to this forum new to trialing so after some knowledge etc hope you lot can HELP
I have just purchased a 1993 GG and am new to trials biking, and was wondering what the fuel mixture ratio is Also is there any common faults with this year (93) ???? Hope some of you experts can help as i want to go out on it tom
