As said above practice makes a perfect better rider
Clutch needs abt 1.5mm freeplay at the lever before engaging the piston, if you dont know when the gear oil was changed change it. Plenty of info on here about type of oiil and amount
If you want to post an image in a reply to a topic that either you or someone else has started then scroll to the “Reply to this topic” box at the bottom of the topic as you would normally do and then click “More Reply Options” in the bottom right:
Once you’ve done that, you’ll see the “Attach Files” section below the reply input box. From here, the process for uploading and attaching images is exactly the same as it is for starting a new topic detailed above.
Hi - problem is, when I do this, there isnt the 'attach files' section............ I have emailed Andy for some help, but none so far..... can anyone help me on this please? An i.t genius I am not! cheers - Andrew
Had a look down the filler cap and I can just about see the fluid down the hole. How high should the level be, would it be close to the top by the cap?
You can fill it up to the top and it it will find the correct level by spitting the excess out
As suggested try tightening the casing to see if that stops the leak if not new gasket but either way you need to sort the waterpump seal/shaft. Dont run it till you have sorted it out
The image just needs to be out on the internet somewhere photobucket picasa etc then click the image button and copy the code to where the image resides
Gas Gas Contact 250 Problems
in Gas Gas
As per the reply in your other post you need to take the carb off and clean out as its been standing for to many years
