neilfrancis
23 -
Hi . Thanks for the reply . I have looked on the web and this company keeps coming up but it has some shocking reviews. The items are too important to me to take the risk.
Hi. Can anyone recommend somewhere to clean and rewax a Bellstaff jacket and trousers. They are a family heirloom so I need somewhere trustworthy.
Hi. Has anyone got a water pump to rad to header tank hose for sale. Thanks
Hi. Mine is standard and has Dellorto PHBH 26mm on it. If you require the spec of the carb I have a handbook with it in.
Hello again. Has anyone got the full spec for a 280 climber carb. I have a good carb but the bike was originally a 240. I would like to know if it's just jets or needle and slide that need changing. Thanks
Hello Again. Has anyone got any idea where I can get the two cylinder head o rings from or an alternative that I can use. Thanks
Bore is 76 mm so Im getting a ring gap of 14 thou. Sounds about right. Thanks
Hi. Can anyone advise on the ring gap on a 280cc climber. Thanks
Hi. I think I've worked it out now. At tdc the disc can either be about 5 mm covering the port or about 10 mm before. There were some faint marks on the case where it had previously been marked. I'm sticking it back together with the port uncovered.Thanks.
Hi. Is the disc valve timing on a climber the same as a swm. Thanks
Im looking to buy a flywheel puller for a 1990 climber Ive just bought. I cant find a specific one on ebay but a bosch rotax one is available. It is a internal thread of 35mm x 1.5. Any ideas if this is the right one. Thanks
Hi. Will a fantic 80cc mono drag my 12 stone around a clubman route. I do have other bikes but this just looked like fun.
Hi.My bike is a TX311M. I was hoping there was something on the market to stop the petrol breathing through. Draining every time might have to be the best option.
Hi I have the usual problem of the paint peeling of my fuel tank. Does anyone know of a product I can seal the tank with,. I know there are products for steel and fibreglass but I dont know of one for plastic. Thanks
Thanks I will have a look tonight.
