sherco34
84 -
Hi I'm having some bother with the fan on my 2012 sherco 125. The bike will start and run however the fan and front light will not come on, i have replaced the fan rectifier but still no luck, the fan works fine when i wired it up to a battery. Any help would be appreciated, thanks.
I'm thinking of re-painting the clutch cover, water pump cover and cylinder head on my 2012 sherco as some of the paint has chipped and worn and doesnt look good. What paint do you reccomend i use to give the most hard wearing finish possible? enamel? powder coating? any other paints? Thanks.
Hi all, Just stripping down my 2012 sherco 125 to rebuild it and i've got to the swingarm but i cant remove the swingarm pivot bolt, ive managed to get it rotationg slightly however i still cannot knock it out. Any suggestions? Thanks.
s3 hardrock aluminium or raptor titanium!!
Is the 2012 sherco 125 supposed to have a mapping switch? I cant find one on mine. Thanks.
Thinking of building a bit of a custom trailer with mini lite alloys and checker plate etc... Im just not too keen on having to compress the forks and suspension when strapping it down, anyone got any alternatives? Also any other things you think might be good to add? Thanks.
theres plenty power in new 125's trust me!
For the front mudguard 'rubber flap' I marked points on the mudguard where to drill holes and then I used 2, short panhead machine screws and 2 large'ish' washers, tightened up with 2 nuts on the inside of the mudguard, simple
is it a repsol one?
My sumpguard on my sherco is pretty bent and i was wondering if i could straighten it somehow to get a bit more life out of it before i buy a thicker 2013 sump guard? Or are there any cheaper/stronger alternatives to a sherco one? thanks. Its a 125 2012
Okay thanks! Think i might invest in one then, also would i need to take the whole clutch casing off to fit the waterpump or not?
Thinking of fitting a high compression head/insert to my 2012 125 sherco. What are the advantages? What are the disadvantages? Are they easy to fit? Thanks.
Thanks very much! great help!
