aussiechris
144 -
Hi Konrad. A proper high voltage probe would have been nice but I just used the clip-on inductive pick up from an old tach/dwell meter - remember those? Also used on timing lights. The red thing below... I just attached a BNC connector to make an easy connection to the scope. I thought it might be better than winding wire around the plug lead. The duration of the spark is extremely short. Unfortunately, at the relatively slow timebase needed to show the other signals, the spark impulse is just one pixel wide. It's hard to see but I just wanted to verify the spark occurs when the ground is removed from the coil - same as a traditional "Kettering" points ignition (and unlike CDI used on other bikes).
Not really. Those stator windings feed three phase AC to the rectifier/regulator to provide 12v DC to power everything. Those are connected via the three yellow wires on the 3 pin plug. There are multiple magnets in the flywheel passing those coils. Ch1 on the scope is connected to the Pulser or pick-up coil shown top right of your photo (with the two mounting holes). It sits external to the flywheel and detects holes and slots machined into the outside of the flywheel. That is connected to the white and green wires in the 2 pin connector. Most bikes have only one slot in the flywheel for timing but the 4RT has a row of nine then a gap. Edit: The Pulser wires are actually white/yellow and green/yellow.
Just a quick update to my original post... I've purchased a more modern 4 channel oscilloscope to replace my old 2 channel unit. This allows me to simultaneously display the relationship between crank sensor, fuel injection, and ignition. The traces are labelled on the left... Ch 1 (Yellow) is the crank sensor or "Pulser" coil. Ch 2 (Pink) is the fuel injector signal. Ch 3 (Blue) is the ignition coil signal. Ch 4 (Green) is the spark plug inductive pickup. The Pulser coil detects a row of holes in the flywheel. There appears to be a slot followed by 5 holes followed by another slot, then 2 more holes. These bursts occur every revolution of the crankshaft. In this shot, the engine is idling at 1720rpm. The fuel injector fires on the negative going pulse and stays open for the duration of the negative pulse (there is +12v on one side of the injector and the ECU pulls the other side to ground). The pulse width determines the amount of fuel injected. This pulse occurs every 2nd revolution of the crank at the start of the intake stroke. The ignition coil also has +12v on one side and the ECU pulls the other side to ground to create the magnetic field in the coil. The spark occurs when that ground is removed by the ECU and the field collapses. So the duration of the negative pulse is effectively the dwell angle (in old lingo). The spark trace is hard to see because it lines up with the trailing edge of the coil input. In any case, the spark occurs every second revolution in between the fuel injection pulses - no wasted spark.
aussiechris started following Head work , New 4RT Owner - How/who can help strip out excess electrical/catch-can bits! , 4RT Wasted spark ignition or not? and 1 other
As others have said, some of those things don't need fixing. However, if you feel the need to remove the Bank Angle Sensor (BAS) then this might help... The BAS is connected via a 3 pin connector inside that blank vinyl boot above the front sprocket. To bypass the BAS and allow the bike to run, you need to jump the two outer wires (the green and the red/white) in that connector. Montesa use very nice sealed connectors from Sumitomo. To do this bypass correctly, you should buy the correct Sumitomo HM090 male connector. and wire it as shown below right (plug the centre hole). Anything else will risk water ingress into the wiring. One place you can get the connector is Cycle Terminal in the USA. Look for "Male half only Natural Male HM090-3 $3.25 each" on http://www.cycleterminal.com/hm-sealed-series-090.html page.
Yes, I was aware there are some fuel pump issues. I'm guessing it's the same problem affecting millions of bikes and cars worldwide fitted with Denso or Assen pumps. Somehow the material used for the impeller absorbs fuel causing it to swell. Road vehicles in many countries are subject to recall and a free replacement (my Honda road bike is one) as it's a safety issue. I've seen no such recall on the Montesa so I'll just keep riding until it fails I guess. But thanks for the heads-up.
I found this snippet from a Honda PGM-FI development document... It's not identical to ours because it's off a scooter but close enough. It notes that the Pb sensor reads manifold vacuum and is mounted downstream of the butterfly valve (point 3 at the bottom).
From the service manual... 1700 rpm is fine. The DC voltage is 13.5v from way below that. It has a very powerful alternator (compared to other trials bikes). I did this testing mostly out of curiousity but it does make a difference if you're trying to attach a tacho that reads off the spark plug wire. There's been discussions about spark timing and fuel injection in the past and I felt the debate was never conclusively settled. In any case, it doesn't hurt to have some baseline data from when the bike is new to help troubleshoot problems down the track.
Yes, that's exactly the way I was thinking. During start up, it would be relatively easy to detect the first sudden pressure drop as the inlet valves open. That would tell the ECU that the next crank trigger pulse requires a spark and the one after requires fuel and so on. I agree. I think the PB sensor incorporated in the throttle body is actually a MAP sensor. Just as an aside, this is part of the ECU wiring from my current model Honda Goldwing. It has both a MAP sensor (in the intake manifold) and a baro sensor (under the seat). Notice that the MAP sensor goes to the input labelled "PB" at B29 whilst the baro sensor goes to "PA". Coincidence, or is this Honda's terminology. I think PB is a MAP sensor.
That's certainly a possibility Konrad. I know my six cylinder car does that so it can detect a misfire and log a code indicating which individual cylinder is missing. It could explain why there's a row of trigger holes in the flywheel rather than a single slot like other bikes. But I was thinking of another possibility. And yes, too curious for my own good!
Warning: long message with copious amounts of techno-babble. I was reading an old discussion on this forum about whether the 4RT runs a “wasted spark” ignition (that is one spark per revolution of the crankshaft) rather than a more conventional (four stroke) one spark every 2nd revolution. It was also suggested that the fuel injection is not sequential but rather injects fuel continuously. Certainly Honda are not averse to using wasted spark ignitions - many of their multi-cylinder bikes do just that. And given the engine does NOT have a cam position sensor, both the above would be reasonable assumptions. However, I think I have managed to prove that the engine does only fire the spark plug every second revolution and the fuel injection also occurs every second revolution timed to intake valve opening (which makes sense given the location of the injector). How? Let’s get technical… I made up some test harnesses to enable me to intercept the wiring at the trigger (pulse generator) coil, the ignition coil, and the fuel injector so that I could view what’s happening on an oscilloscope. At my (slow) idle speed of around 1700rpm, the crankshaft is rotating 28.3 times per second or once every 35 milliseconds. The crank trigger coil sends pulses to the ECU every time a hole in the flywheel passes by. The flywheel actually has a row of holes/slots that pass the trigger coil, then a gap with no holes and that gap or burst occurs every 35mS. The pic below shows the output of the trigger coil on Ch1 in yellow. The blue trace (Ch2) is the ECU signal going to the ignition coil primary. You will note that it only occurs every 2nd burst of trigger pulses. The ignition coil pulses are about 70mS apart (each grid square being 10mS) so that is about 14.2 times a second or 850rpm. That’s half the crank rpm of 1700. So what about the fuel injection? Unfortunately I only have a two channel scope so in the following image, the Ch1 yellow trace is now the fuel injector signal. The blue trace is still the ignition coil showing the relationship between the two. You can see how the fuel injector fires in between each ignition pulse. This is always the case regardless of rpm. The injector is firing every 70mS just like the ignition coil except one crank rotation out of phase. I did some measuring and the injection pulse* occurs 34.8mS before ignition spark… Given the time for two revolutions (720°) is70ms, then fuel injection is commencing about 358° before the spark which sounds about right - just before the intake valves open at the end of the exhaust stroke (taking into account spark advance and valve overlap). The injector pulse duration (the negative bit) at idle is about 2ms long (just over 20° of crank rotation) but is visibly longer when the throttle is opened. So, in summary, this engine definitely fires the spark plug every second revolution (at the end of the compression stroke) and injects fuel sequentially just prior to the intake stroke. That just leaves one question for ya’ll to ponder… Since the engine does not have cam position sensor (or points), how does it know which stroke it is on? It would be easy to suggest it just fires the spark plug every second crank trigger but it has to pick the correct one to align with the camshaft otherwise it wouldn’t run. I have a theory on how it might achieve this every start but wondered if someone else would like to offer an opinion. Looking forward to your comments. * Note: the above traces are referenced to the +13.5v power. Both the ignition coil and fuel injector are switched to ground by the ECU. The spark plug fires when that ground is removed (the end of the negative pulse) but the fuel injector opens when the ground is applied (start of the negative pulse).
I would think so. Obviously it would need painting afterwards. Having said that, the original bracket looked like unpainted cast/forged stainless steel when new but it did go rusty later on. Some stainless steels do rust. Be warned, the spring will be a bear to get back on after moving that perch point 😠
My 2015 260 was fine with regards to the side stand. But my 2022 301 was not. It came with the self retracting stand -supposedly for safety reasons but doesn't work so well with a right side stand if you mount/dismount from the left. Anyway, before even riding the bike, I removed the side stand bracket for modification. As you can see, the spring perch is slightly behind the pivot... I hacksawed it off and re-welded* it forward of the pivot... Works fine now although the spring is stretched a bit more than it should be. It now stays extended until I kick it up... * The bracket is some sort of steel or possibly stainless steel. I TIG welded it using stainless filler wire.
I'm a bit late to the party but I thought I'd mention that I used a rod kit from HotRods for repairing my 2015 4RT 260 and it worked perfectly. Their part number is 8616. Original rod on the left... Specs are on the lines for CRF250R or CRF250X... Sources might be: https://www.allballsracinggroup.com/8616-connecting-rod-kit Or in the UK: https://www.motocrosspartsuk.com/honda-crf-250r-x-2004-2017-hot-rods-connecting-rod
Good luck with that !!! Honda/Montesa don't supply a rod kit as a spare part. They expect you to buy the entire crankshaft assembly for some hideous amount of money. I recently replaced the rod on my 260 4RT and used a rod kit from Hot Rods in the USA. Fortunately it is the same rod as a Honda CRF 250X or R (04 to 08). The Hot Rods part number is 8616 and the dimensions are - centre to centre 90mm, small end bore 16mm, big end bore 38mm, small end width 15mm, big end width 17.8mm, pin diameter 30mm, pin length 52.85mm, big end bearing 30 x 38 x 18mm, side thrust washers 1mm. The rod kit includes big end pin, big end bearing, and thrust washers but not the piston pin or clips. It is stronger than original (slightly heavier but runs smooth). Photo shows the original rod on the left. Parts with KRN on them (or KRN in the middle of the part number) come from a CRF250. Hope that helps.
What oil fuel mixture (and oil brand) do you use on your 2 stroke Gas Gas?
aussiechris replied to thesaint's topic in Gas Gas
All the guys I ride with run 100:1 (usually Motul 800 full synth) in modern liquid cooled bikes and have been for the past 15 years or so. And most of our bikes are between 5 and 10 years old now with no oil related problems. On the odd occasion we've pulled an engine down, there is tons of oil on the piston/crank etc. Feel free to run richer mixtures for peace of mind but I am yet to see any evidence that 100:1 has caused any premature wear or issue. And replacing or repacking clogged mufflers is a hassle I'd rather put off as long as possible.
