happycyd
    38
2,158 profile views
  1. Have you dated the bike properly - use the frame numbers .Yamaha YBR125 engine will slot straight into frame - add a 150 conversion . Works just fine . I know I’ve done it a few times ,
  2. Hi there , if you’re looking for any bike spares/bits - I’d recommend scorpasalive on eBay . I’ve dealt with Tony for years - very helpful. He only breaks Sy250’s . enjoy the bike
  3. happycyd
    Scorpa CDI
    Try Scorpa’s alive on eBay - Tony has broken them for years and may have one available. I’ve dealt with him for years
  4. Hi there , Nigel Birkett at Birkettmotosport . He was the importer and May still have spares - a very helpful guy , he’ll be a bit tired this week coming - he just finished the SSDT 69 years young 👍
  5. Get decent boots - they’re worth the money - use your heating allowance 😀😀😀👍🏾
  6. Hi spooky , I had a hip replacement 10 years ago - ridden the last 9 of them in trials - albeit at a “b” route level ( omitting certain sections ). I’m now 69 and intending to continue - Dumfries trials are great as are Dalmellington trials . Most clubs cater for old farts like me 😀 most of the issues are in your own head ( lack of confidence ,etc ) .it will take you a while to get bike fit ( recommend cycling is good way to strengthen legs , at our age ).. Ride what you feel comfortable with at all times and have fun - we ain’t going to win any trials all the best
  7. As someone who falls ( no pun intended ) into this category, there is a lot of sense in this article . However , joint damage over many years abusing one’s body , can cause issues with the indicated exercises . Thai chi is a good solution . Cycling outdoors is a good way of maintaining lower body strength ( not necessarily total off road - gravel / track riding ) does help whilst keeping the loads on lower joints acceptable ( relatively pain free ) . That’s my two penny worth ,
  8. Looks like the case hardening has broken down - therefore worn and makes changing gear difficult - replace selector drum ?
  9. A braw looking “ting tong” . Toni will do really well on it . Build quality looks superb - look forward to seeing the production version . 👍🏾
  10. Scorpa 125cc 2t is good bike quite forgiving and easy to kick over ( r/h kickstart )
  11. They call them “ ting tongs “ home created from fertile imaginations and good engineering skills ,ridden regularly up here successfully . Magic idea
  12. What kind of quality control does that suggest about the rest of the build ?
  13. Easiest way to do this - go to EBay - type in Scorpa and then parts - look at listings for frames bikes etc and you can contact Tony that way
  14. Contact Tony at Scorpa’s alive - he only breaks Scorpa’s - good guy to deal with - I have done so for years - advertises on EBay
  15. You need to split the crankcases to access the gears - its an interesting task - use a parts manual to locate how components go together - use the t&mx build sequence - good luck
