gaz0203
    3
  1. thanks for the advice, what sort of job is it to replace the pump seal? so far all i hav removed is the round alloy side plate to remove the clutch, thanks
  2. well been having trouble with the clutch draggin on my newly acquired jtr 250, i understand its sometimes common for the clutch to be dragging slightly but this is to the point where if i apply the brakes it stalls the engine. i changed the oil this morning for dexron 2 an somehow managed to make it worse. so ive taken the plunge and decided to get inside the clutch. iv noticed that the friction material has started to part from the metal backing on more than 3 of the discs, also the metal plates are smooth, but have lots of dark areas that look like possible rust where its been sitting. im guessing its had water in the oil at some point. im hoping this is going to cure the majority of my troubles, wheres the best place in the uk to get a full clutch kit from? thanks
  3. hi, ive just bought myself a gas gas jtr250 as a first trials bike, im after some help in setting it up. firstly what tyre pressures should be run front and rear? im starting to play around in the yard tryin to sort my balance out and learnin to hop but i find it very hard to get it to leave the ground. is it best to have the front shocks set more to hard or soft to make this easier? at the minute there almost all the way to soft, thanks
