disco1001
25 -
Stolen 2 Bikes Scarborough N.yorks 24.02.2015
disco1001 replied to disco1001's topic in Stolen Bikes
Totally agree Steve. I intend a full lock down system with loud bells and flashing lights....scare the living daylights out of any hooded scrotes.... -
Thanks for advice... Yes UK is rife for m/c theft. has been for years... Dont ever hear of police busting major players. Perhaps the theives (scum) are to organised, or police time is needed elaswhere...shame. Gutted for my son (16) as he worked hard all summer and saved for his bike....not insured also... Learnt my lesson...future bikes will be road registered, insured and stored elsewhere in a seriously secured location.... Future attempted theiving bstrds will be caught on camera, identified using social media, hunted down and dealt with accordinaly (private)... -
Stolen from locked house shed in Scarborough N.Yorks. Bikes chained together with Heavy Duty Oxford chain link locks Thatcham approved. Bikes removed still locked, carried as one. 2 helmets and 2 pairs of boots including a number of oil containers also taken. All other items in shed such as tools, cycles not touched. Targeted theft. Bike details: 2007 GAS GAS TXT 300 CC Red and Black. 2007 Sherco 250 CC Blue / Yellow with black frame and wheels. Very good reward offered. Information received in confidence. Bike serial Nos available. Contact me (Darren) on 07795497185.
Thanks for the info...will remove clean, inspect and try again.....used lots of (wd40) to get them in both times.......what a numpty Disco
Please can someone give me some advice or reason as to why the hell my 4 pot AJP caliper will not seal when new seals and pots have been fitted. Cleaned all componets.....grooves clean ...seals in ....pressed pots into caliper by hand..with a little help with spray oil.... All together back on bike and still p****** fluid out when pulling brake...HELP...this is my second set......and £50 quid in all ready.... Any advice appreciated....
Thanks for the link b40rt... Will get one of these and add it into the one i am removing...then will have a back up if ever needed... Cheers Mate,
Looks like its a sealed unit...thanks pal...
Update:...Bingo....Back running...Thanks to all postmen...and Zippy for the recent advice...all taken onboard... Cut the split ht back even more...now only about 6cm in length..replaced plug cap for new, one more suitable which just ,makes the plug top.... Binned the 2 spark plugs and replaced with new.... Off she whent running sweet... From what i saw...i believe the issue was too much bend in the ht lead, also split and maybe the plug cap or plugs also contributed... Also ordered new CDI unit...dont like the short length im running with now...will swap...just to make me feel more confident in reliability... All good advice given.....the best one for me...'was work backwards' dont go straight for the CDI / stator....(which i nearly did)....may save you money...and effort Funniest was hold onto the ht lead with your hand.....haha....my 15 year old lad was the one who drew the short straw,,,,,but it worked and hes ok..... Happy Man...again...big thanks to all. Im sure i will be back again...
yes been switching between 2
Update: Took the plug cap off the ht lead, removed plug from barrel and cranked by hand..held lead in hand..SPARK...is back????? if this was the stator...would this happen...anyway reconnected all and tried to kick of.....nothing...again... The ht lead when plug and cap is in position is so short with a shcoking right angle....also outer sleave lining split.....is this ok..normal for this Sherco...my sons beta & GG are much longer with no right angle bends... Wondering if im losing spark because the seriously short lead and tight bend.....maybe arhcing across somewhere? Going to fit new plug cap tomorrow to see if it does the same....if it does maybe its time for an new CD? or will the HT length be the same? thats my worry? All suggestions / experiences appreciated...
thanks again..will do the simple & cheap changes then get it to someone whos handy with bike stators & multimeters if the changes fail....
Hi JFC......To dissconect kill switch is it just a matter of unpluging at connection in line? or do you need to do something else? Thanks for input so far,,,will eliminate and update... Kill switch & Plug cap & condensor 1st...i think.... Disco
2007 Sherco 250...Running fine for the past 6 mths. Stalled at trial....took 10 mins to get going again...ran for 2 more mins then died as if carb clogged...Would not start again.... On visual inspection weak spark then totally disappeared. no spark......Cleaned all connections / earths...still nothing....No spark. Im going to try a spark tester on the plug....just to confirm loss of current... Is this the best basic method.....sorry dont know how to use a volt meter... Whats the most likely unit failure if spark not there? And how can i eliminate step by step...when replacing parts...which to go for 1st? Any starting points / advice will be much appreciated. Disco
Bike / carb now runs brilliant. Starts 1st time / every time and hasnt dumped any fuel since carb adjustment / new float valve. Thanks Darren.
