duffers
    36
  1. looking at the picture the gap between your adjuster and the lug on the swing arm shouldn't be there, it looks as if the adjuster has turned with the nut.
  2. Not sure what yours are, but i fitted a set of NJB Trick shocks to my Montesa and they are great. I am a bit heavier than you and they handle anything I chuck at them. Good value as welL. Different springs available and easy to set up and adjust.
  3. Mikuni - available jetted for the bike from in motion, fitted one to my Montesa mh200. It makes a huge difference, better all round and ultra reliable.
  4. Have you checked the water pump is circulating the coolant, if not this can cause rapid overheating and lead quickly to the piston seizing in the barrel.
  5. Excellent tyres, have them on all three of my bikes. Very popular in the south of the uk.
  6. Good choice of bike, I ride a trial on mine every week and its yet to let me down. I would recommend you check it selects all the gears and finds neutral. The 200 gearbox is probably the weakest part of the bike. Check that the kickstart returns and has a return spring fittled. The engine oil drain plug is difficult to get at (under right frame tube) these are often damaged with stripped threads. If the bike has been open to the elements check the aluminium components for corrosion particularly the fork yokes and if you can access them the brake drums. The akront wheel rims do tend to get a bit knocked about but as you intend to have them refurbed that should sort them out. If you are getting the seat unit resprayed check the fibreglass on the area around the seat and rear shocks this is the part that usually gets damaged or cracks and would benefit from some additional fibre glass to strengthen it. Also make sure tank does not leak. If you need to knwo more pm your phone number. I love these bikes and have had mine apart loads of times (also getting another one soon) I can probably tell you all you need to know about running one and who stocks the parts. Regards, Paul.
  7. Running it to lean could cause overheating.
  8. Chris, recently had the same with my 280 Pro resulting in the bike seizing and a costly bill for repairs. In my case it was the water pump that had failed, not sure if you are familiar with how this operates but basically the plastic impellor had stripped its left hand thread and was not turning with the shaft and therefore not circulating the coolant. A repair kit is available for about £70-£80 or the complete unit is about £150. Just to let you know I could not find fault with my pump until it was stripped down. Hope this helps and you fix it soon. Duffers.
  9. I have just had mine done, Genuine soles cost £28 from trials uk and my local cobbler fitted them. A word of warning though - the soles are very soft and it takes a lot of work to grind to grind the old soles off. The cobbler fitted them for £20 agreed before he had done the work. He said it should really have been double the cost for the time it took.
  10. My Montesa 314 R has been stolen from my garage some time over the last 4 days. Please let me know if you hear of anyone trying to sell one. It is easily recognised as it has 315 forks fitted and many mods to the rear subframe and brakes. many thanks, Paul.
  11. Lineway - what makes this such a terrible bike? Fred, I have one its my first modern trials bike and I get on fine with it. Their are many ways to tame it if necessary with a smaller front sprocket and a slow action throttle. Its reliable and parts are easy to get hold of. I really rate it - I tried the others and any of them would have been great but i liked the feel of the gas gas. I obviously can't say if it would suit you but i would certainly ignore advice that writes off anything as terrible when so many people are using them at all levels. Give a few a go then buy what you like best.
  12. I think this highlights how potentially damaging "no stop" could be for our sport. For many years tennis had arguements over disputed points so they brought in hawkeye, football is looking at goal line technology and rugby uses the tv referee. It is sad that at the top level, unless each competitor is video recorded from a number of angles in each section the decision will rest with the observer and it will be the observer who incurs the wrath of the the competitor. Who will want to observe with this added responsibility? What happens at lower levels where video is not an option and observers give up their time for a coffee a burger and the love of the sport? Still, new bike sales must be booming!
  13. Good choice and very pretty, bet you can't wait to get it messy.
  14. I run 9 - 42 with a slow tube on my 280 Pro. Tamed it a lot, but can easily be changed back in minutes.
  15. I thought the purpose of this thread was to identify a couple of bike thieve's. Funny it only took two posts before the priority changed to slagging off the police! DISAPPOINTING!
